My laptop lenovo turns on normal but there is no blacklight background looks dark the image, I measured the voltages of the screen and everything is fine except for 19v to activate the blacklight
need help with l340-15api .... fg 542 fg 543 fg 742 nm-c101
Re: need help with l340-15api .... fg 542 fg 543 fg 742 nm-c101
I need schematic for " fg542 fg543 fg742 nm-c101 rev:1.0 " board. I have two resistors sufated that must be replaced, but i dont know they value. I add pics for if anybody can say me this valors or can share the schematic. Thanks.
https://drive.google.com/file/d/1HDP...ew?usp=sharing
https://drive.google.com/file/d/1__E...ew?usp=sharing
https://drive.google.com/file/d/1uSP...ew?usp=sharingComment
SchematicComment
BoardviewAttached FilesComment
by bodtechHi
I have an ipad, it gives a red screen error and restarts. I re-molded the U1600 and U1800 ICs and threw in the software. Ipad is working but I can't activate it. I changed serial wifi blt emac, I couldn't activate it again, (i did unwifi ) I re-sofware every step to make sure, could it be another hardware failure? I would appreciate it if you could help me if you have come across and solved it.
iPad Air 2 A1566 -
by SiddigHi. I need Solutions to change serial number to bypass I cloud activate or serial address section in hexadecimal . Attached dump file.
Model:MacBook pro 13" M2 -2022
motherboard: 820-02773
EMC 8162
Serial number:WVK0329042....-
Channel: BIOS Requests ONLY!
by senchaHi,
Is it possible to activate AMT /w KVM feature on Dell Precision 3630 using a method similar to the one (i.e. fptw64) used on Optiplex series?
Thanks -
by PiggymuHi, I'm trying to fix the wifes tv and this is my 1st time working on a modern tv (worked on some tubed tv's along time ago).
After lots of googling i need to activate the power supply like you do a pc's (tv is dead, no led etc). now i'm thinking i need to bridge POWER_TV with 1 of the SGND points to activate it?... -
by questoreHi Everyone,
I have this ASUS tuf laptop that had a shorted GPU mosfet repaired but since the short pulled suddely 6 amps from battery and if went to locked state.
The cells are ok Voltages are above avarage and the heated fuse also not blown.
The problem is that battery still not gives out voltage.
I cannot spend 445 Dollars on an NLBA just to unlock 1 battery. Is there any reset I can perform, or any cheaper solution for unlocking or alternativly should i jump the 2 mosfets? - Loading...
- No more items.
