How to activate locked battery
  • questore
    • Dec 2015
    • 499
    • csongrád
    Hi Everyone,
    I have this ASUS tuf laptop that had a shorted GPU mosfet repaired but since the short pulled suddely 6 amps from battery and if went to locked state.
    The cells are ok Voltages are above avarage and the heated fuse also not blown.
    The problem is that battery still not gives out voltage.
    I cannot spend 445 Dollars on an NLBA just to unlock 1 battery. Is there any reset I can perform, or any cheaper solution for unlocking or alternativly should i jump the 2 mosfets?
  • mon2
    • 14182
    We DID buy this tool but got run over by a drunk driver that works for our decaying city.
    Very risky to play with the cells raw. There are protection layers in place for your safety. I believe Sorin had a video on this topic but going from memory here. My vote is to bite the bullet and purchase a replacement pack.
    PS: From a very very quick review - the tool is based on tinkering with the BQ / Texas Instruments charger IC and their never ending banks of registers. Using the proper permutation, you may be able to resurrect a dead cell, etc. You may be able to gain the same experience by purchasing an EVK from texas instruments who owns BenchmarQ IP.
    PS#2: Watch this video:
    https://www.youtube.com/watch?v=Hd9s...GarageMaxedOut
    Should be ok to use this method which is using a dedicated cell charger which will be safe by design to awaken the dead battery pack cells. Not sure about the locked BMS which I understood to be a well kept secret.
    • questore
      • Dec 2015
      • 499
      • csongrád
      Yeah, my problem is that cells are ok, battery practicaly new, with 2 cycles but locked. No repait shops have nlba around to unlock it
      • rumpumpel1
        • Jul 2019
        • 149
        • germany
        have you asked in the NLBA forum where the nearest repair shop with an NLBA device is?
        • mon2
          • 14182
          They are in Romania.
          • anhbanxoi
            • Sep 2021
            • 172
            • VN
            If you have EV2300 or EV2400 I can help to unlock the battery.
            • mon2
              • 14182
              anhbanxoi - yes, please do. I believe I have one of these too at the office (need to check what has not been crushed by the drunk).
              • questore
                • Dec 2015
                • 499
                • csongrád
                Good Idea thank you.
                Does EV2400 has a software coming with it ?
                • mon2
                  • 14182
                  Yes. You can download it from the Texas Instruments website.
                  • questore
                    • Dec 2015
                    • 499
                    • csongrád
                    Thanks i have already done it, When i get home i check if this battery chip is compatible with the ev2400. Maybe i give it a try and let you know the result
                    • rumpumpel1
                      • Jul 2019
                      • 149
                      • germany
                      you can also use the EV2300/EV2400 with the NLBA Software.
                      • mon2
                        • 14182
                        Interesting...did not know this. Thanks.
                        • questore
                          • Dec 2015
                          • 499
                          • csongrád
                          Yes you can buy it and use it if it worth over 100$ a year and you know you have enough people who will pay for battery
                          Our country is poor, most of the laptops come with compleatly dead battery or no battery at all .
                          • mon2
                            • 14182
                            You can download the standard software from NLBA website for free.
                            • rumpumpel1
                              • Jul 2019
                              • 149
                              • germany
                              make sure, you install the SW in the right order as defined on the NLBA download page.
                              • questore
                                • Dec 2015
                                • 499
                                • csongrád
                                Thanks i will try
                                • Bowline
                                  by Bowline
                                  06-11-2025, 10:13 AM
                                • mkdj
                                  by mkdj
                                  Mark and model: ASUS X571
                                  Tests already made:
                                  - I have removed...
                                  07-14-2025, 09:16 AM
                                • techfreak9356
                                  Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                                  by techfreak9356
                                  09-14-2023, 11:10 PM
                                  NVDC charger configuration...
                                  11-05-2024, 03:28 PM
                                • ferah831208
                                  by ferah831208
                                  03-18-2025, 01:18 AM
