MagicBook 14 2019 bios
  • tahc81
    • Nov 2019
    • 42
    • Slovakia
    Originally posted by yarikoslav
    Are you sure that the dump file is unlocked?
    BTW do you have a bios dump for MagicBook 14 2019 KPRC-W10L?
    After all, I've found I've got MagicBook 14 2019. EC replaced, tried several BIOSes from Huawei web, but still not working.
    Attaching original BIOS dump, no guarantee of a functionality! Based on a dump analysis, looks like it's BIOS version 1.16
    $BVDT$ $ $1.16 $H98A $05.32.42
  • mkdj
    ASUS ZenBook UX480F : need help with cleaning the ME region of my BIOS dump
    by mkdj
    Dear all,
    I have a ASUS ZenBook UX480F with the following symptoms:
    I suspect it is a BIOS issue. So I decided to try to clean the ME region. I followed the guide on win-raid, and I believe I have done everything correctly. My problem is: when I open the outimage.bin in ME Analyzer, it says that it is Extracted, and not Region, Extracted as it should be. Is it normal, or did I do something not correctly? This is my first experience editing BIOS files.
    I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...
    10-19-2025, 04:41 AM
  • Habble7
    I need a BIOS dump for the Samsung S49CG934SU monitor
    by Habble7
    The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
    Suspected Cause:
    I suspect the BIOS may have been corrupted during a power interruption while updating the firmware. The official website provides firmware updates, but they can only be installed via USB flash drive.
    Troubleshooting Attempts:
    05-22-2025, 07:28 AM
  • haitham sharabati
    [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
    by haitham sharabati
    Hello engineers 😀,
    I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
    🔧 Device Info:
    - Model: HP 15-da2007ne
    - Product Number: 8XF55EA#ABV
    - Serial Number: CND0338P0D
    - CPU: Intel Celeron N4000
    - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
    💀 Problem:😅
    - Device shows “Administrator Password”...
    08-07-2025, 04:54 AM
  • Citymin
    NT955XED (Samsung Galaxy Book2 Pro - 15.6) BIOS dump file Request
    by Citymin
    My Samsung Galaxy Book 2 Pro 15.6-inch laptop has no display and won't boot.
    The charging red LED lights up, but the charging screen doesn't show any indication.
    When I press the power button, the blue LED cycles on and off three times, then the screen doesn't turn on, and the device won't boot.
    (I've tried removing the battery and resetting the device, but the issue persists.)
    NoteBook Model name : Samsung NT955XED-KK51G(Galaxy book2 pro, i5-1240p, 15.6inch AMOLED)
    PCB model name : Venus2-15-5G(REV1.2), Venus2-15 ADL NPC
    S/N : 5RNK9FFT70...
    08-05-2025, 05:12 AM
  • DynaxSC
    MSI PRO B660M-G DDR4 - real bios dump from board needed (no stock bios)
    by DynaxSC
    Hi, I have an MSI PRO B660M-G DDR4 board with damaged BIOS and i need a bios dump from a real board, along with MAC, UUID and Serial Number info (eg. a BIOS screenshot and pictures from the board stickers).
    I need to reconstruct the bios on my board, based on another bios image form a real board - meaning a bios image containing MAC address, UUID and Serial number. A stock BIOS is not suffiecient, as it is impossible to discover where the MAC, UUID and SerialNumber are stored. Tried with a similar board, but there are too much differences, and the stock BIOS is missing a lot of...
    11-17-2023, 10:56 AM
