HP 15-db0070ns laptop (LA-G078P) : does not power on, had liquid inside
  • dicky96
    Sun Seeker
    • Mar 2017
    • 1825
    • Spain
    Hi guys
    I have this HP laptop for repair. The owner says that their cat knocked a vase over, and water had been dripping into the laptop for a few days.
    They then left on one side for several months. Either the owner or the technician who brought it to me tried to power it up but it does not start
    I did not try to power it up, though I did check the charger is OK
    There is some corrosion on the HDD around the spindle/motor area
    There was also some corrosion on and around the KB9022Q D SIO
    I cleaned all this up with ISO. There is a MLCC capacitor very near the SIO that looks like either the input or output capacitor to a buck regulator near the SIO. This was badly corroded and one end cap was missing so I replaced it with a new 10uF MLCC, not knowing the correct value
    Once I fixed those problems i tried to power it up, it seems totally dead.
    I have 19V getting through the first two MOSFETs after the DC in socket. The third MOSFET has 19V going in and 3V coming out. There is a buck inductor on the other side of the PCB under this MOSFET and that also has 3.0V so it is probably a standby supply. I can't see any CMOS battery on the motherboard so that kinda makes sense
    There is no voltage on any other inductor. The battery only appears to have 2.95V on two of the pins and nothing on any of the others.
    I can't find a datasheet for the KB9022Q SIO. I did a resistance check and the 3.0V 'standby?' supply does not directly connect to any pins on the SIO.
    I then had a look around the SIO for any sort of power supply and I only find 0.5V on one pin, nothing else (other than a few pins reading 0.1V-0.2V)
    I'm kinda assuming the SIO needs a 'permanently on' supply of some sort before it can power up anything else on the motherboard.
    I tried to check for 3V on the power on switch but it looks like the contacts are not accessible to test that.
    Does anyone have any further ideas, info or even better a schematic for this laptop?
    Rich
    Follow me on YouTube
    Learn Electronics Repair
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: HP 15-db0070ns laptop (LA-G078P) : does not power on, had liquid inside
    There is a jumper PJ303 near PU301 which is your 3v Regulator. PJ303 is the 3.3V LDO which powers the kbc. So first check whether you have 3.3V on PJ303. If yes,remove kbc and check voltage on vcc pin pad of kbc again . If the voltage appears on kbc vcc pin after removal of kbc-then you need to replace the kbc. However, if you dont have 3.3V on PJ303, then remove the jumper and check whether you have 3.3V on PU301 side of jumper. Do measure resistance on jumper PJ303 before doing anything.
      • 21917
      Can you tell me what marking is on PQB1 please ,to help another member with the same motherboard - https://www.badcaps.net/forum/showthread.php?p=1082614
      • sanaa
        • Jul 2019
        • 3
        • freand
        thx good
        • Flaku_34
          Acer Nitro XV273 and Predator XB273, look inside and disassembly guide.
          by Flaku_34
          Introduction:
          Hello everyone, this topic is more of a knowledge sharing and look inside type of post, but for someone working on this model of display it might be useful. Recently I bought Acer Nitro XV273 XB MIIPRZX with busted electronic, but screen was intact, price was incredibly low, so I took a gamble and bought the unit and try to fix it. As I dug inside, I found out that my motherboard was not responding, although all voltages seemed fine. I wasn't able to find any reliable information about this monitor on the web (only some pictures of motherboards from Ebay). By some research...
          04-18-2024, 12:47 PM
        • silver60618
          How to clean Liquid Metal from under CPU?
          by silver60618
          Hi all, Im working on a board, that my customer brought to another shop, and smeared liquid metal all over the board.
          The laptop powers on, then shuts off. I noticed traces of Liquid Metal near the edge of the CPU, but I fear some maybe underneath.
          Has anyone ever tried Ultrasonic cleaning, or compressed air to remove or agitate the liquid metal?
          07-11-2025, 01:47 PM
        • Hondaman
          Liquid cooling?
          by Hondaman
          I hope my computer does not randomly reboot while typing this. My main system is the AsRock 970A-G/3.1 motherboard with the AMD 8150 chip. I am experiencing FREQUENT and RANDOM reboots once the system is used for a couple of hours (sometimes it reboots before I even get to the Win7/Linux Mint dual-boot screen). The problem MIGHT be the DRAM controller chip (I recently upgraded to the maximum 64 GB RAM). It also might be the VRM chips. I am using a typical aftermarket CPU cooler, which does NOT blow air DOWN onto the VRM heat sink.
          (After previous generation hardware [Gigabyte] didn't...
          05-08-2025, 09:37 PM
        • kurland
          Strange liquid on damaged GTX1080 card
          by kurland
          I'm fixing a GPU card for a streamer, was sent to me by mail. A shorted cap on a power rail has severely burned the PCB.
          As you can see from the darkened PCB around the mosfets there are signs of liquid damage. But it's odd because the person says no water has entered the PC cabinet. If you spill something on a desktop you would know I guess...
          Funny thing is that the liquid is not only on the PCB but on top of many chips which are tightly covered by thermal padding under the heatsink, even on top of some of the RAM chips
          11-17-2020, 07:14 PM
        • mitchw
          MacBook Pro 16 M1 Pro Liquid Damage (820-02100)
          by mitchw
          Got a MacBook Pro M1 Pro 16'' to rescue immediately after liquid accident - I got it in less than 30 minutes after the spill.
          It got spilled from behind when the laptop was closed. It mostly affected the rear of the mainboard and the bottom of the LCD.
          I quickly took it apart and washed the liquid residue off the mainboard.
          The area around the UP800 had some light corrosion, but it just washed away with some IPA. Other areas looked undamaged.
          The mainboard got a thorough cleaning, as did the top case and LCD connectors / cables.
          Now the laptop...
          07-16-2025, 07:55 AM
