Sharp LC-52SB55U (No Power)
  • ddjmagic
    • Oct 2021
    • 8
    Hi all, I'm looking for some help with Sharp LC-52SB55U.
    It's a US model, but currently being used in the UK for a few years (TV is 100-240V Power)
    Currently the TV does not power on, no lights or noises when the power button is pressed.
    I was not present when the TV stopped working but apparantly the TV randomly 'clicked' a few times while the green light came on and off a few times, since that it hasn't powered on or shown any lights.
    I have taken the TV apart and the power board is RDENCA295WJQZ (DPS-277BP)
    I've checked for voltage on the PD connector and there is 0v on any of the pins (including the one marked BU5V)
    I've confirmed power is getting to the board, and the main bridge rectifier (D15XB60) has 240V AC and 300V+ DC.
    I can't seem to find any schematic for the power board, so a bit stuck on trying to find the issue.
    Any help or advice to troubleshoot further is appreciated.
    Thanks, Dan.
  • lotas
    • Jan 2016
    • 4803
    • Russia
    Re: Sharp LC-52SB55U (No Power)
    Dps-277bp
    • ddjmagic
      • Oct 2021
      • 8
      Originally posted by lotas
      Dps-277bp
      Great, thank you. I'll have a look through that.
      Anyone know of any common problems/most likely issue on this board?
      • ddjmagic
        • Oct 2021
        • 8
        The last place I seem to be finding any DC voltage is diode on the center of the board (D7908).
        I've checked D7908 & D7909 (next to it) in circuit and both are showing very low resistance in both directions (0.02), other diodes I can see test 0.6 & OL, so potentially D7908/D7909 diodes could be the issue?
        Would the next step be taking them out of the circuit and test again?
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          That would be a better way of being certain if one or both are faulty.
          • ddjmagic
            • Oct 2021
            • 8
            Thanks. D7909 tests fine off the board but D7908 is still testing bad off circuit.
            D7909 test good back on the board. So it seems that D7908 diode is no good.
            Does anyone know where in the UK something like this could be purchased?
            Could potentially something else have casued the bad diode?
            • lotas
              • Jan 2016
              • 4803
              • Russia
              Look for this name of the Zener diode D7908 - 1N5383BRLG.
              • R_J
                • Jun 2012
                • 9607
                D7908 usually checks open and will be ok it is a high voltage tvs diode. In circuit, the transformer primary is across the diodes.
                Check that R7914 is ok,
                Check the voltage across C7918 and C7915, it could be that both caps are bad and not letting the standby power supply section run. These caps can go open.
                • ddjmagic
                  • Oct 2021
                  • 8
                  D7908 seems to be showing a short on the tests? Unless I'm reading the meter wrong (also has continuity both ways)
                  R7914 seems to test all good, there is no voltage at C7918 or C7915 at all.
                  • R_J
                    • Jun 2012
                    • 9607
                    If D7908 checks shorted, then it is bad. Try replacing it and see if the circuit operates. The fact that it is shorted basically across the transformer primary would cause the circuit not to function.
                    • lotas
                      • Jan 2016
                      • 4803
                      • Russia
                      This is a protective diode, to check the power supply, you can turn it on without it, if everything starts, then the problem was only in it.
                      • ddjmagic
                        • Oct 2021
                        • 8
                        Thanks for this. I can confirm with everything back together except D7908, everything operates and powers up correctly.
                        I just need to find a replacement diode now and I think I'll be good to go.
                        Thanks everyone for the help.
                        • lotas
                          • Jan 2016
                          • 4803
                          • Russia
                          1N5383B - Zener Single Diode, 150 V, 5 W
                          • ddjmagic
                            • Oct 2021
                            • 8
                            I managed to source this diode, soldered it back in and TV is all back together now and working great
                            Thanks again.
                            • Tynan Dill
                              by Tynan Dill
                              Assuming...
                              11-22-2024, 01:46 PM
                            • PantherDave
                              by PantherDave
                              Hi all!
                              05-29-2024, 02:01 PM
                            • GLISIT
                              by GLISIT
                              01-16-2025, 02:29 PM
                              by sam_sam_sam
                              03-31-2024, 02:12 PM
                              09-06-2024, 05:59 AM
