Eeprom dump thread!
This is a sticky topic.
    Re: Eeprom dump thread!
    I have a toshiba 40l3653db with flashing green light, found this forum & thread searching google unsucessfully for firmware.
    Can anyone help, point me to any appropiate firmware?
    Its the vestel 17MB110 main board, screen is VES400UNDS-2D-N12.
    Thank you.
      good afternoon, I have a polaroid TV tql40f4pr006 with the main board HK-T RT2957P63 panel V400HJ6-PE1-P7-12V for which the eprom dump was needed.
      thanks
        Hi, I need the bin file for Magnavox 55ME314V/F7 A4GR1MMA, panel U4DR0XH. I have the DUMP file but is corrupted, I am using the BIN file for the DS3 but I got inverted picture. Thanks
          Post your non-working dump here, I'll try to fix it.
            Here it is. Thanks
              Here it is. Thanks
              Try this Dump.
                The fixed file works!!! but the picture is still inverted, same as when using the 55ME314V/F7 DS3 file, Thanks
                  Here you need to try to enter the service mode through the remote control (you need to know exactly what code to dial on the remote control) and change the "mirror" item to ON or OFF.
                    good afternoon, along with the dump that works
                    thanks
                      thanks
                        Originally posted by Cantv View Post
                        Hello , some one can share with me the EEPROM DUMP FOR Samsung tv UN60H7150 . Thank you in Advance .
                        I tried to read the eeprom for you but was unable to. Tv does work and has no problems at all.
                        For some reason this eeprom wont read. I tried a few others and they all read no problem.
                        Is there a trick to reading this one?
                          Firmware needed please for a polaroid p43d300fp
                          lcd panel VES430UNDA-2D NI2
                          MAINBOARD 17MB110P 23397404
                            For me in the archive is mb110 not 110p. If you want you can try.
                            https://files.fm/u/ve6hh359y
                              Thankyou i will give it a try is it best too remove the ic and programe it that way using a ch341a
                              Edit just downlaoded the file i tried to extract it says no archive is either unknown format or damaged i have tried downlaoding it twice
                                Changed to a diffrent pc downloaded files ok if using a ch341a which files do add? i have never really used a ch341a before thanks
                                  I checked. The archive is good. Use another unzipped or newer version. Installation is done from the stick not with CH341.
                                  Do you know the installation procedure for Vestel electronics?
                                    I picked two sets up yesterday for free both seem too have firmware issues, i have just ordered remotes for both sets so cant try the firmware until remote comes.
                                    please can you explaine the update procedure step by step and i will give it ago i have 1gb and 2gb usb memory sticks so hope that will be ok. Thankyou for your help.
                                        You need the remote control for installation. The installation is done with the OK key.
                                          Hopefully remote will come either today or tomorrow, what format do i need too wipe usb stick with and could you please tell me the procedure i will print if off for future refrence thanks.
