"#" symbol on sch.
    "#" symbol on sch.
    What does this "#" symbol usually at the end of a signal name/function mean on a schematic?
    Sorry just starting out looking at laptops for fun, and can't find this info
    Re: "#" symbol on sch.
    Most at times it indicates a low signal, a signal to send another signal low e.g SUSP=3.3v but you need SUSP#=3.3V to make SUSP to be 0v
      Logic signals (as opposed to power rails or data lines) communicate answers to simple questions. For example, SLP_S3# answers the question "Are we in an S3 or lower sleep/power state?
      There are two possible answers (true/false). And to represent these it uses 2 possible voltages (often 0V/3V). But which voltage means "true" and which means "false"? That's what the '#' character tells you.
      Plain signal name: 3V = True, 0V = False
      Signal with a '#': 0V = True, 3V = False
      Technically, the former is referred to as an "active high" signal, and the latter as an "active low" one. This is because the first one uses a high voltage to represent a true condition, while the second uses a low voltage to indicate the same thing.
      Sometimes a different character is used rather than "#" (e.g. an "_L" suffix). But it shouldn't be too hard to figure out the method by just glancing around whichever schematic you are reading and using some common sense.
        Thanks for that detailed explanation. That really helps
          Thanks for the technical explanation
