CTV-606
security guard dropped his tv on the floor and now it only plays wavy lines, if you change channel there is a different wavy lines. there is no menu coming up though.
i have reseated the flat cable and also i soldered another bit of cable on the left side because it just came away. still no luck. the construction is wierd. looks like a lot was hand soldered.
any ideas?
the cable on the left to the screen what does it do?
regarding the antenna (which is not the problem because he uses external antenna) it was connected to the board with a coaxial cable which came away also. i put a single cable for the time being cos i cant see where the two points on the antenna are. should there be two points?
any ideas?
