When the power button is pushed, the front LED blinks but the TV doesn't turn on. Unplugging the main board from the power supply, the backlight flickers. Checking the strips with an LED tester, they all test good.
PFC voltage on main caps is 392V and drifts a couple hundred of millivolts. B5V is stable at 5.2V. B13V is around 11V, not stable and drifts +/-1V. Since this supplies the LED driver IC, I believe either the PFC or 13V supply side is the main suspect.
PS is BN44-00645D. BN44-00645A schematic should be close.
