Maybe someone here can help me. I bought an Vizio m70-c3 on craigslist for $175 that needed backlights. It had a beautiful picture just really dim in some spots. Tested the leds and alot were out. Ordered some from shopjimmy and put everything back together and now the pic is screwed up. Any advice would be greatly appreciated.
70in Vizio m70-c3 replaced led's now picture screwed up.
Re: 70in Vizio m70-c3 replaced led's now picture screwed up.
replacing LEDs in 60 and bigger displays is a time consuming job that takes a lot of patience and temperament. buying one for more than $30 is not advise-able in my opinion. your set is probable parts nowLast edited by ajshoe; 02-12-2018, 11:57 PM.
Originally posted by freakaftr8 View PostTake a better picture of the screen if you can. Looks as if the right side gate driver with that white band goes all the way across the screen is the area that is badd
Originally posted by freakaftr8 View PostThat's mura, not fixable, but may be caused by the failed gate driver on the right side of the panel. Panel and tcon manufactured by sharp.
Originally posted by sawilson View PostI've been reading your posts about peeling off the tabs from the panel. Do you think this could help?
Yes it appears that this is your only saving grace now.Did I leave the soldering iron on?
No heat needed just gently pull each tab away from the panel like you're peeling tape off of something. Start from the top and work your way to the bottom both side boards (upper and lower) all cables on that side. When you're done you will have to boards connected by a ribbon with all the ribbons hanging off the boards Like you saw in my pictures on my post they were sitting on the tileDid I leave the soldering iron on?
Pictures taken. Now, I have 4 small boards (2 sets of 2connecte by an mid ribbon) attached to the bottom of the panel. These are connected by 4 ribbons coming of the boards on back of TV. Do I peel off the ribbons on the far right of the papan, 5th pic?Last edited by sawilson; 02-14-2018, 10:55 AM.
