Go Back   Badcaps Forums > General Topics > General Computer Discussion
Old 04-26-2018, 11:17 AM   #21
RJARRRPCGP
City & State: North Springfield, Vermont
Line Voltage: 123-127V 61.5-63.5 Hz
Default Re: Paxville or Bust! The Supermicro X6DA8 Project
Originally Posted by Topcat View Post
I diddled around with this a little this morning... Mainly for testing purposes to make sure I have working hardware. This test is with the Irwindale processors. Of course this post was created from it. Wtaerfox 56.1.0 functions excellent on it. Quick load and smooth as silk browsing....although I haven't put it through the youtube test....
I now remembered one of the sucky parts about SCSI, its the slowest booting bastard, even though its U320 with a 15k RPM HDD. Once it boots, its fine (benchmarks to come when I get it to a permanent state).
Missing caddies located and replaced.
CPU-Z:
More to come, but back to my other project for now.
CPU-Z shows wrong Vcore value, SMH...
https://ark.intel.com/products/codename/5960/Irwindale
https://ark.intel.com/products/codename/6191/Paxville
Asus P6T6 WS Revolution
Core i7 Extreme "Bloomfield" 965
Asus Strix GeForce GTX 970
Windows 7 SP1
SoundBlaster ZXR
Corsair TX850M PSU
"Don't eat yellow snow!" -Salem
RJARRRPCGP is offline   Reply With Quote
Old 04-26-2018, 11:27 AM   #22
Topcat
The Boss Stooge
Topcat's Avatar
City & State: Salem, MO
My Country: United States
Line Voltage: 120VAC 60Hz
Now that you mention it, yea. If they were running at 2.6v, they'd be melting.
Just to be sure, I checked the BIOS monitoring, its where it should be. Bug in CPU-Z I guess....my *guess* would be that CPU-Z is adding the 2 VCORE values into one reading.
<--- Badcaps.net Founder & Owner
Badcaps.net Services:
Premade Capacitor Kits
Badcaps.net Capacitor Master List
Motherboard Repair Services
If you've come here in search of replacement capacitors or repair services, please use the links above.
http://folding.stanford.edu/
Team : 49813
Join in!!
Team Stats
Topcat is online now   Reply With Quote
Old 04-26-2018, 12:40 PM   #23
Stefan Payne
City & State: Northern Germany
My Country: Germany
Line Voltage: 230VAC/50Hz or 400VAC/3P/50Hz
This system was the freebie from the county. Stellar solid Enlight case with Enlight 470w PSU. I did the usual inspection of the PSU (whch appeared to be working)....and lo & behold, some bad fukyou caps, but otherwise its a very beefy PSU.
still a garbage PSU, as are (almost) all Topower made ones.
That one looks like it doesn't have the active PFC Board, does it??
And its either P4 or P5 series...
And the big heatsinks are due to really shity efficiency - the one's I've seen are around 65%, maybe lower 70% range...
Even if it seems fine, I'd throw it away and use a more trustworthy unit...
Stefan Payne is offline   Reply With Quote
Old 04-26-2018, 12:48 PM   #24
RJARRRPCGP
I did that to my 2007 GeForce 7600 GS, LOL. Focking FZ caps!
Old 04-26-2018, 01:20 PM   #25
Topcat
The Boss Stooge
Topcat's Avatar
I'm not using that PSU in this build, I haven't even messed with it beyond taking the cover off. I have a couple Supermicro PSU's to choose from (a 865W and a 665W, both are Ablecom built), and those are bulletproof.
The pics shown are using a bench supply, Antec HE650 (seasonic & recapped)....good PSU's.
Old 04-29-2018, 11:54 AM   #26
Topcat
The Boss Stooge
Topcat's Avatar
I piddled around with it a little this morning, I got the case debadged, sticky goo removed, and washed out.
Just a few pics...
So much awesome!
Even more elderly PC awesome!
More later.
Old 04-30-2018, 11:10 AM   #27
Topcat
The Boss Stooge
Topcat's Avatar
I assembled this system this morning. Its so nice working with well-built cases!!
I ended up using a 500w Supermicro PSU (Not sure who OEM'd this one)...Yes RD, its that one that came out of one of your new cases many moons ago. I used it in another system, and sold it a few years ago....the client upgraded and I ended up with that system back...and here we are.
Anyway, I want to change HDD's around a bit. It's running a single 146gb 15k RPM. I want to get a few more and try a few different SCSI RAID configs, for benchmarking & testing purposes....but its running & stable right now, in an awesome & clean case. Fun project for under 100 bucks!
Photographic goodness....
Here's the Crystal DiskMark for a single drive U320 15k RPM on an Adaptec 2120S RAID controller....yikes its slow compared to SAS! I'll retest this when I can run it in a raid0/10.
I'll hunt down some drives whenever I have some more free time... This post of course created from the freshly assembled Irwindale Awesomeness.
Old 05-02-2018, 06:11 AM   #28
Snayperskaya
City & State: N/A
My Country: Brazil
Pretty nice to see old server-grade still kicking. But I can't help and be nervous when I see a pile of boards stacked up without an ESD bag. Hahaha
Snayperskaya is offline   Reply With Quote
Old 05-02-2018, 06:43 PM   #29
momaka
momaka's Avatar
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
I'm a: Hobbyist Tech
No, this one is actually a pretty reliable PSU. Just has pretty low efficiency, like you said. It's basically a 5V design with a "beefed-up" 12V rail. Of course, like any oldschool design like that, don't expect to pull full total label power on the 12V rail or even half of that without some serious sag on the 12V rail. But all in all, it's a good PSU and is more than adequate for the system that it was running (sans the Quaddro FX4800, of course).
That said, be glad this PSU didn't come with APFC. Otherwise, that efficiency number would have been even worse. Not to mention make a big dent in reliability. Only real server-grade PSUs can be considered reliable with APFC, at least from what I've seen. The APFC garbage we see in consumer units today is just a ticking time bomb. A few years and *bang* goes the primary cap(s). I have seen very very FEW oldschool PSUs with voltage-doubler circuit have their primary caps go bang (usually, it's from incident with the 115/230V switch set to 115V on 230V mains). In contrast, I have seen a considerable amount of "modern" units with blown APFC circuits / primary caps - even with Japanese brands.
ESD is rarely a problem, unless you live in a really dry climate or store your stuff in a dry room environment (especially with carpet).
I too rarely store my stuff in an ESD bag. Here on the US East Coast, there's too much moisture in the air during the summer and fall for ESD to be a problem. On the flip side of that, moisture causes contacts to tarnish a lot quicker. And if you store your stuff in an underground / basement with lots of dust, that's almost equivalent of storing your stuff under water, lol.
Old 05-02-2018, 09:15 PM   #30
Topcat
The Boss Stooge
Topcat's Avatar
Thats why I didn't use it in this build....I'm going to recap it and store it for a retro box....some oddball P-classic through P3 era system. This system would be a little overwhelming for it, not only for the higher TDP netburst CPU's, the FX4800, and then add in 4x 15,000RPM HDD's (the originals were 2x 9.1gb 7200RPM)...
Old 05-03-2018, 02:25 AM   #31
brethin
City & State: Owensboro, KY.
Those systems are great fun to build but none want them. I have a room full of fun builds going back to the 8086 8088 days and while I love them like my kids, all they do is take up space and collect dust.☹️
brethin is offline   Reply With Quote
Old 05-03-2018, 08:11 AM   #32
ratdude747
Black Sheep
ratdude747's Avatar
City & State: Madison, IN
I have one (X6DA8-G2, Twin 3.8 Irwindales w/ Geforce 9800GT GPU) as my living room PC. Does that make me weird?
It struggles a bit on 1080P 60 frame youtube videos , but otherwise it does what it needs to...
(Insert witty quote here)
ratdude747 is offline   Reply With Quote
Old 05-03-2018, 11:34 AM   #33
RJARRRPCGP
By how much? A jerk fest like a later-2010s Braswell laptop CPU?
The (Pentium N3700, IIRC) laptop that was given to my sister was shit, when it came to 60 FPS 1080p YouTube videos!
Old 05-03-2018, 12:35 PM   #34
ratdude747
Black Sheep
ratdude747's Avatar
Stutters every 3-10 seconds. Lots of buffering but not due to the actual buffer.
Old 05-03-2018, 01:15 PM   #35
Topcat
The Boss Stooge
Topcat's Avatar
...and another strange sleeper is born... Finally got around to testing this X6DAL. It's the DDR1 version, I've got 8x 2gb sticks, so populating all 6 slots gives me 12gb.....good enough. It flunked the Paxville test, it would only recognize one CPU (both cores), but socket 2 was not seen. This board came with a pair of 3.6GHz Irwindales, of course both CPU sockets show and function with the Irwindales installed.
...but I've got a couple old P3-era beige Aopen cases that this might fit nicely in...
Old 05-04-2018, 01:29 PM   #36
RJARRRPCGP
I think I had that kind of issue before, even with a Core 2 and later, IIRC, LOL.
Old 05-05-2018, 12:05 PM   #37
Topcat
The Boss Stooge
Topcat's Avatar
...and here's the start...I'll just throw this build into this thread since they're kind of 'cousins', no need for a new one.
What better use for an old beige Aopen case...
Some modifying will be required (which makes it more fun anyway):
Old mATX P4 system (momaka, let me know if you want it, it works).
More to come....
Old 05-05-2018, 06:17 PM   #38
noppa
Maybe you should try an updated version.
noppa is offline   Reply With Quote
Old 05-05-2018, 08:45 PM   #39
Topcat
The Boss Stooge
Topcat's Avatar
...and looky what turned up in the junk pile...
Old 05-05-2018, 10:32 PM   #40
ratdude747
Black Sheep
ratdude747's Avatar
^I have the PNY "energy efficient" version in my irwindale box... slighly less performance (underclocked a tad), but uses a slimmer heatsink and is under 75W (no PCIe power connector, which is good since that PSU doesn't have it).
