Does anyone know where I can find Windows XP update from
    I have some old desktop computers that were given to me ( no they did not come with hard drives )
    The installation disk that I have of Windows XP is when it first came out
    I have a Radio Shack meter that I want to use on it
    The manual says Windows XP ( or higher but we will see if this is the case or not )
    This meter has a serial port not a USB output
    I going to recap the mother board and power supply on one of these old desktop that has serial port so I do have not to use a converter box
    I do not plan to use this computer on the internet but I know that Windows XP had updates I have to see if I can find the update disk I know I have but can I find it that the question it was so long ago
    9 PC LCD Monitor
    6 LCD Flat Screen TV
    1 Dell Mother Board
    15 Computer Power Supply
    All of these had CAPs POOF
    Re: Does anyone know where I can find Windows XP update from
    Windows uppdate for xp should still work, you may need to find ie8setup for windows xp and install it first, I don't remember. If not there are lots of copies of windowsxp_sp3 around on the internet.
      https://getintopc.com/softwares/oper...nload-1339359/
      https://getintopc.com/softwares/oper...nload-6960719/
        Or you can install what you have and get sp3 etc. from the microsoft update catalog site https://www.catalog.update.microsoft...q=windows%20xp
        Or for windows xp sp3 iso https://isoriver.com/windows-xp-sp3-iso/ you will need to provide your own licence key
          Thank you for the links this will help me a lot
          9 PC LCD Monitor
          1 Dell Mother Board
            Thank you for these links this will help me a lot
            9 PC LCD Monitor
            1 Dell Mother Board
              If you have an original install XP CD (that is, no service packs integrated), or just one with SP1 or SP2 only - do NOT connect the PC to the Internet! -Not even for updates!
              SP2 and older versions are still susceptible to getting infected with a worm known as "DownAdUp". You don't have to go to any website - it will get picked up automatically. SP3 has an update that addresses this vulnerability. That said, I still have SP2 PCs on the net, but they have been patched specifically for that vulnerability: update KB958644. You will need Windows Installer 3.1 to run this update, though (KB893803).
              But really, just get an SP3 ISO and be done with that - probably easier and a little more secure.
                Here are some of the part numbers of the versions, searching the part number will likely result in an CD ISO
                English:
                Windows XP Professional (SP3) Retail - Part No. x14-80428
                Windows XP Professional N (SP3) Retail - Part No. x14-92445
                Windows XP Home (SP3) Retail - Part No. x14-92413
                Windows XP Home K (SP3) Retail - Part No. x14-92386
                Windows XP Home KN (SP3) Retail - Part No. x14-92388
                Windows XP Home N (SP3) Retail - Part No. x14-92393
                Windows XP Professional (SP3) VLK/Corporate/Volume - Part No. x14-73974
                Windows XP Professional KN (SP3) VLK/Corporate/Volume - Part No. x14-92432
                Windows XP Professional K (SP3) VLK/Corporate/Volume - Part No. x14-92430
                Windows XP Professional N (SP3) VLK/Corporate/Volume - Part No. x14-78118
                Windows XP Professional (SP3) Checked Build - Part.No x14-92469
                Windows XP Professional (SP3) OEM - Part No. x14-72249
                Windows XP Home (SP3) OEM - Part No. x14-73422
                  is the radioshack multimeter in this list?
                  https://sigrok.org/wiki/Supported_hardware#Multimeters
                    Wrong thread .
                      Originally posted by SMDFlea View Post
                      Wrong thread .
                      Not really, read post #1
                        lol - always read a whole thread before jumping in!
                        because if it's all to read a multimeter, and if sigrok supports it - then we dont need xp at all.
