Go Back   Badcaps Forums > Motherboards with Bad Capacitors > Abit - Asus - Aopen
Old 10-10-2016, 05:07 AM   #1
Bungz
City & State: UK
My Country: UK
Default Asus P5K SE Choke replacement
Hello
I have the above board and while it works perfectly one of the chokes whines and I would like to replace it.
http://static.nix.ru/autocatalog/mot.../67037_top.jpg
My question is that R68 chokes are very common, I can harvest off a dead board but does it have to be the exact same as is currently on the board or are all R68 stamped chokes equal?
Thanks!
Bungz is offline   Reply With Quote
Old 10-10-2016, 11:23 AM   #2
mockingbird
mockingbird's Avatar
Default Re: Asus P5K SE Choke replacement
There's no harm in trying it, and they're not polarized.
Good luck desoldering it though and then clearing the holes afterwards.
...Their plight, in fact is even worse, they don't realize that they're cantonists, they think they're free men. What a slavery that is - to confuse slavery for light, and bitter darkness for bright light.
-Rabbi Menachem Mendel Schneersohn
mockingbird is offline   Reply With Quote
Old 10-10-2016, 12:49 PM   #3
Bungz
City & State: UK
My Country: UK
Desolder station makes short work of them
Will see if I have anything that fits in the pile of death
Old 10-11-2016, 10:45 AM   #4
mockingbird
He he, lucky you...
It took 4 or 5 episodes of Sherlock Holmes over here just to desolder and clear the holes off the VRM low caps on an Asus P5B-VM.
They must have used some secret nazi lead-free alloy... The stuff is almost impossible to remove.
Old 10-11-2016, 12:26 PM   #5
Th3_uN1Qu3
Believe in
City & State: Bucharest
My Country: Romania
Line Voltage: 230VAC 50Hz
If you don't have a heatgun, do the work with the board on top of a griddle or room heater and it'll go much faster.
Originally Posted by PeteS in CA View Post
A working TV? How boring!
Th3_uN1Qu3 is offline   Reply With Quote
Old 10-11-2016, 01:50 PM   #6
mockingbird
Thanks, will do
Old 10-11-2016, 09:44 PM   #7
momaka
momaka's Avatar
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
I'm a: Hobbyist Tech
Unless the noise is really annoying you, I wouldn't worry about it.
If it's a toroidal inductor, you can also try to "pot" it with glue (but the glue has to be non-corrosive).
I sometimes use wood glue for stuff like that.
I used to do that (pre-heat board with heat gun) when I only had my 30 Watt Radio Shack iron. It works, but.... meh. Don't expect miracles.
There's no replacement for a soldering station with T12/T15 tips, though (or if you have money, a JBC ). Takes me a minute or less to take out even the toughest coils.
