Asus P5K SE Choke replacement
  • Bungz
    • May 2013
    • 133
    Hello
    I have the above board and while it works perfectly one of the chokes whines and I would like to replace it.
    http://static.nix.ru/autocatalog/mot.../67037_top.jpg
    My question is that R68 chokes are very common, I can harvest off a dead board but does it have to be the exact same as is currently on the board or are all R68 stamped chokes equal?
    Thanks!
  • mockingbird
    • Dec 2008
    • 5484
    Re: Asus P5K SE Choke replacement
    There's no harm in trying it, and they're not polarized.
    Good luck desoldering it though and then clearing the holes afterwards.
    • Bungz
      • May 2013
      • 133
      Desolder station makes short work of them
      Will see if I have anything that fits in the pile of death
      • mockingbird
        • Dec 2008
        • 5484
        He he, lucky you...
        It took 4 or 5 episodes of Sherlock Holmes over here just to desolder and clear the holes off the VRM low caps on an Asus P5B-VM.
        They must have used some secret nazi lead-free alloy... The stuff is almost impossible to remove.
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          If you don't have a heatgun, do the work with the board on top of a griddle or room heater and it'll go much faster.
          A working TV? How boring!
          • mockingbird
            • Dec 2008
            • 5484
            Thanks, will do
              master hoarder
              • May 2008
              • 12170
              Unless the noise is really annoying you, I wouldn't worry about it.
              If it's a toroidal inductor, you can also try to "pot" it with glue (but the glue has to be non-corrosive).
              I sometimes use wood glue for stuff like that.
              I used to do that (pre-heat board with heat gun) when I only had my 30 Watt Radio Shack iron. It works, but.... meh. Don't expect miracles.
              There's no replacement for a soldering station with T12/T15 tips, though (or if you have money, a JBC ). Takes me a minute or less to take out even the toughest coils.
