I never EVER look at the output of any inverter, unless it bears a Pure Sine Wave claim and I'm running inductive loads, for the same reasons that I don't routinely examine septic tank efficiency. Cuz eww.
If you're looking for a decent UPS: my UPS is a Xantrex PROsine 2500 with 0/1 cables running through the wall to an outdoor steel cabinet full of Walmart truck batteries. It outputs a sine wave (if it's isolated during measurement) even at its safety trip point of 118VAC 29+ amps which is substantially more than its rated 2500W. It can (and has) run my PC, monitor, Asterisk server, network, and rework station, for 4 days straight. It didn't turn on its cooling fans until power was back and it had to recharge all those batteries. Those Xantrex guys sell the good stuff.
I also just got a "UNGE" sine wave inverter from the wee folk in Shenzhen. $130 means I didn't expect it to really produce 600W sine waves. I was wrong. This thing outperforms its specs by a bit less than 15% (I pushed it until it just started to clip, then backed off a little). It did that for two hours w/o overheating. It uses squirrely parts, and I'll be replacing those in a few years, but this might be a Xantrex Killer. Add two $20 Advance Auto economy car batteries and I get a 600W sine wave UPS that can run for hours for only $170.
When testing electrolytic catzappers, you should always wear an OSHA approved safety squint.
- Friedrich Nietzsche
Re: Database of UPS inverter output waveforms @ HWI
Ancient BK400EC added. I've also started measuring inverter efficiency (at least roughly for some general idea) under full load, where possible, this has also been added for the BK650EI.
HP T750 G2, Eurocase EA620 and Riello NDG 200 measurements have been added. Hopefully none of that will get lost with more migrations etc. as the Smart-UPS text got :-o
