Database of UPS inverter output waveforms @ HWI
  • Behemot
    • 4845
    • CZ
    Re: Database of UPS inverter output waveforms @ HWI
    Got three more APC units (BK650EI, SU620INET, SMT750RMI2U).
    • Behemot
      • 4845
      • CZ
      And one more, the SUA2200I.
      • GeorgeBlitz
        • Oct 2017
        • 24
        Originally posted by Behemot
        Nice!
        I never EVER look at the output of any inverter, unless it bears a Pure Sine Wave claim and I'm running inductive loads, for the same reasons that I don't routinely examine septic tank efficiency. Cuz eww.
        If you're looking for a decent UPS: my UPS is a Xantrex PROsine 2500 with 0/1 cables running through the wall to an outdoor steel cabinet full of Walmart truck batteries. It outputs a sine wave (if it's isolated during measurement) even at its safety trip point of 118VAC 29+ amps which is substantially more than its rated 2500W. It can (and has) run my PC, monitor, Asterisk server, network, and rework station, for 4 days straight. It didn't turn on its cooling fans until power was back and it had to recharge all those batteries. Those Xantrex guys sell the good stuff.
        I also just got a "UNGE" sine wave inverter from the wee folk in Shenzhen. $130 means I didn't expect it to really produce 600W sine waves. I was wrong. This thing outperforms its specs by a bit less than 15% (I pushed it until it just started to clip, then backed off a little). It did that for two hours w/o overheating. It uses squirrely parts, and I'll be replacing those in a few years, but this might be a Xantrex Killer. Add two $20 Advance Auto economy car batteries and I get a 600W sine wave UPS that can run for hours for only $170.
        When testing electrolytic catzappers, you should always wear an OSHA approved safety squint.
        - Friedrich Nietzsche
        • Behemot
          • 4845
          • CZ
          OMG, not this crap again?! I don't want no car accumulator BS in my thread. Car accumulator belongs to car.
          • goodpsusearch
            • Oct 2009
            • 2848
            • Greece
            why?
            • Behemot
              • 4845
              • CZ
              #26
              Cause, well…car? ᗡ-:
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8666
                At least get trolling accumulators...
                (hmm, was this supposed to be a double entendre post?)
                • goodpsusearch
                  • Oct 2009
                  • 2848
                  • Greece
                  #28
                  I do that since 2011 without any problems.
                  • Behemot
                    • 4845
                    • CZ
                    #29
                    Added the BR1200G.
                    • Behemot
                      • 4845
                      • CZ
                      #30
                      New garbage Eaton, 5E1500IUSB.
                      • Behemot
                        • 4845
                        • CZ
                        #31
                        APC SUA1000I's been finally added
                        • Behemot
                          • 4845
                          • CZ
                          #32
                          Also the good ol' SU1400INET.
                          • Behemot
                            • 4845
                            • CZ
                            #33
                            Ancient BK400EC added. I've also started measuring inverter efficiency (at least roughly for some general idea) under full load, where possible, this has also been added for the BK650EI.
                            • Behemot
                              • 4845
                              • CZ
                              #34
                              I've added one more Eaton unit (what a garbage!) and couple APC efficiency measurements.
                              • Behemot
                                • 4845
                                • CZ
                                #35
                                More measurements of different values of units already in the DB have been added over the year, and also the ol' APC Smart-UPS 900.
                                • Behemot
                                  • 4845
                                  • CZ
                                  #36
                                  HP T750 G2, Eurocase EA620 and Riello NDG 200 measurements have been added. Hopefully none of that will get lost with more migrations etc. as the Smart-UPS text got :-o
                                  • Behemot
                                    • 4845
                                    • CZ
                                    #37
                                    Couple more units added lately, including pretty shameful CyberPower BU600E.
                                    • FrancescoV
                                      Onkyo HT-R390 no sound output, video output ok
                                      by FrancescoV
                                      Good morning everyone,
                                      I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                                      The firmware reported is the following:
                                      M:1.00/11107BLP
                                      D:?.??/????????
                                      O:1.00/11107AL
                                      The DSP firmware given the question marks seems corrupt.
                                      On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                                      05-11-2025, 02:59 AM
                                      NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
                                      by sam_sam_sam
                                      I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
                                      I bought this from an eBay seller but unfortunately they only had one
                                      I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
                                      I bought three of from them to also make battery packs with this output power limit in mind
                                      I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
                                      04-23-2025, 05:50 AM
                                      Corsair CX750M [Model 75-002019] - burned output toroid inductor
                                      by momaka
                                      Looks like I may need a little help from the PSU experts (or anyone really! ) I have a Corsair CX750M (Model 75-002019) that I picked up for free about 4 years ago. This is the PSU:
                                      So here’s what’s strange about this one: it appears to work normally (normal output voltages) and any PC is stable with it. However, after a while (typically 10-20 minutes, but time can vary depending on the load), there is a sweetish smell of burned magnet wire insulation emanating from the PSU. Upon opening the PSU after this happened (many times), I was able to confirm...
                                      09-19-2021, 08:44 PM
                                    • organman
                                      Sharp LC-60LE633U Inverter output voltages
                                      by organman
                                      Greetings, I have a Sharp LC-60LE633U when powered up only the V light comes on. I have checked the LED strips and they all light up. When the LED's are plugged into the PS board I get an output voltage of 74v DC. If I unplug the LED's the output voltage on the PS is 184v DC. Does this indicate a weak PS?
                                      Thanks...
                                      03-22-2023, 06:47 PM
                                    • organman
                                      Sharp LV-60LE633U inverter output voltages
                                      by organman
                                      03-13-2023, 06:48 PM
