Identify Capacitor
    Identify Capacitor
    Please help me find a data sheet for this so I can replace it.
    Trec NP?? not sure if NP is for non-polarized or for the series. NP series seems to be a fiction, so I presume it's some other mysterious series. They are purple.
    Any ideas on what series it is??
    Thanks,
    Ryan
    Re: Identify Capacitor
    NP usually stands for non-polarized and based off of your photos i think those capacitors are non-polarized as i don't see a negative stripe on those capacitors.
    From what i can find it they could be trec BR series or trec NR series capacitors.
    I'm not a expert, I'm just doing my best.
      Thanks Ruky Con for the quick response. I did read it right after you posted, I just remembered I never thanked you. So here it is, a bit late.
        No problem at all. I don't mind the late thank you.
          Thanks,
          Ryan
          Personally, I never come through non-polarized cylindrical capacitors. This schematic might help you.
            Yes that's a non polarized/bipolar electrolytic capacitor. Usually the characteristics of these capacitors are pretty crappy to begin with so likely you can replace with almost any crappy np/bipolar electrolytic capacitor of the same capacitance/voltage.
            Which side is negative?
            This was the first cap I saw that marked both sides...
              NP CAPS are used a lot in speaker cross over, and also in Class D amplifier output.
