Badcaps.net Forum
Go Back   Badcaps Forums > Motherboards with Bad Capacitors > Abit - Asus - Aopen
Thread Tools Display Modes
Old 08-14-2017, 06:09 AM   #1
kevin!
recapping PCB.
kevin!'s Avatar
City & State: Gerona
My Country: España
Line Voltage: EUR 230VAC 50Hz
I'm a: Hobbyist Tech
Default Asus K8V-X SE Polymod CPU VRM
I have an Asus K8V-X SE board with nippon-chemicon KZG 6.3v 1500 microfarads capacitors defective, I made full VRM the polymod, with capacitors os-with SEPC 820 microfarads 2.5v. At the moment it works very well, I am writing this post with this computer.
__________________
Gaming pc :
AMD FX8350. Motherboard gigabyte ga990fxa-ud5. 12 gb ddr3. Hitachi 500GB, x2 Western Digital 640 GB SATA +WD 320GB, gpu: nVIDIA GTX760 windows 10. PSU corsair RM750I, chassis NZXT S340. Mouse Logitech Laser, keyboard Corsair strafe RGB Cherry RED.
Server PC:
HP 3130MT:
Future server 10Gbps ethernet
HP COMPAQ DC7900 SFF
Intel core 2 duo E8400, 4GB of the ram, 500GB HDD.
kevin! is offline   Reply With Quote
Old 08-15-2017, 03:11 AM   #2
momaka
momaka's Avatar
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
Default Re: Asus K8V-X SE Polymod CPU VRM
It's a fairly "modern" motherboard, in terms of VRM design, so it should have no problem with poly caps around the CPU.
I see at least two more free/unpopulated cap spots on the CPU V_core (CPU low side). I like to fill those in when I can. If you got spare poly caps, feel free to do so. Should make the VRM even more quiet in terms of noise - good for overclocking or undervolting (depending if you want to get more performance or low power use - those AMD chips are awesome under-volters - if there is even such a term ).
Old 08-16-2017, 02:19 AM   #3
Uranium-235
Radioactive
Uranium-235's Avatar
City & State: tehas
My Country: US
Line Voltage: 120VAC 60Hz
I'm a: Professional Tech
its not "fully" vrm polymodded unless the VRM-IN (the panasonics next to the parallel port) are polymers too
i'm guessing 16v 1500uf?
polys will have to be 16v, and just find the highest uf you can, you won't find 1500
__________________
Uranium-235 is offline   Reply With Quote
Old 08-16-2017, 03:52 AM   #4
stj
stj's Avatar
City & State: Europe
My Country: some shithole run by Israeli agents
you can, you can go to 2000uf
however, you cant leave it like that - every time you look at it you will want to replace the remaining caps too!
stj is offline   Reply With Quote
Old 08-16-2017, 10:14 AM   #5
Uranium-235
Radioactive
City & State: tehas
My Country: US
yeah I stand corrected, you can get higher uf. With some crazy 8A ripple and .08Ω
http://www.mouser.com/ProductDetail/...u22R%2fg%3d%3d
Old 08-17-2017, 09:25 PM   #6
kevin!
recapping PCB.
kevin!'s Avatar
My Country: España
Ok, I'll put more to compensate for the loss of capacity. So far with the 6 there is no abnormal noise, and the capacitors are cold, and I have it overclocked at 2.4GHz to 1.4v
I think the polymod output worked well, but since you say so I will put more capacitors in the empty areas.
The old ones are 6.3v, the rail is going to work less than 1.8v, these sanyos that I put are those used for CPU VRM, I think they are sufficient, although as said the companion would be well put more capacitors in the empty areas.
I have been able to make a stable 2.4GHZ OC to 1.4V on an AMD 3000+ (2GHz stock)
You mean the 16v input?
They are pannys, they are in pretty good condition, I made the polymod to the output of the CPU, excuse me explain badly, so far I have not had a single problem with the computer, I even get a stable 2.4GHz OC.
I think that with 6 of 820 microfarads is enough, I understand that the polymer capacitors equals one of electrolytic of more capacity, for example poly is 820, electrolytic is equivalent to 1500 microfarads.
The 16v of the rail of 12v I have not changed, they are panny and they are in good conditions, what I replaced was the VRM output faulty nippon chemicons of the CPU, that does not exceed the 1.8v, with the SEPC of 2.5v is sufficient.
These are the capacitors I put on it:
http://www.mouser.com/catalog/specsheets/SEPC_OS.pdf
Thanks for your tips .
In the area marked in red in the image, they are the ones that change for the Sanyo.
Old 08-18-2017, 03:11 PM   #7
momaka
momaka's Avatar
My Country: U.S.A.
Well, it's not necessariy, like I said. But I like to do it anyways, just because I always tend to have extra caps from Xbox 360 motherboards that are suitable for around the CPU.
2.4 GHz at 1.4V? Nice!
Is the 1.4V on the core stock, or did you reduce it? I have a 3200+ Newcastle core, and it runs on 1.5V stock. I haven't tried over-clocking it much, but when under-volted to 1.325V from the stock 1.55V, I get 7-10C drop in temperatures load-idle temperatures, respectively. So instead of 53C under load, the CPU maxes out at 46-47C.
Old 08-20-2017, 06:31 AM   #8
kevin!
recapping PCB.
kevin!'s Avatar
My Country: España
Yes, I was pleasantly surprised to have overclocked 2.4GHz to 1.4v, I worked, but today I plugged the computer and started to hang, I discovered that it is the fault of the AGP bus, it seems that even if I put it locked at 66MHz, when I go A FSB so high the chipset becomes unstable, It's a shame because the CPU holds up very well and likes very much the overclock, to see if I get a better motherboard and I can give more overclock.
The temperature is maintained above 114 ° in the bios, it seems to me a suitable temperature.
Old 08-22-2017, 11:04 PM   #9
ChaosLegionnaire
HC Overclocker
City & State: Singapore
My Country: Singapore
Line Voltage: 240VAC 50Hz
did u try to overclock the fsb to more than 250mhz? the via k8t800 pro and non-pro chipsets both have a fsb limitation of around 250-260mhz. any higher makes the chipset unstable even with working pci/agp locks. it is for this reason that ppl preferred nforce chipsets for overclocking. however, the flip side is that nforce is affected by bumpgate.
ChaosLegionnaire is offline   Reply With Quote
Old 08-23-2017, 09:29 AM   #10
kevin!
recapping PCB.
kevin!'s Avatar
My Country: España
Quote:
I had it at 240MHz, at 233MHz it works better.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums © 2003 - 2018
Powered by vBulletin ®
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
