Re: Enlight HPC-250-101 is aging
When it comes to resistors, brand doesn't matter that much - even the cheap Chinese ones tend to be just fine.
In any case, I also suggest grabbing a 150 Ohm resistor, just in case R25 really was the low resistance that it showed initially. That way, if the PSU doesn't work with the 1.5 KOhm resistor, you have an alternative to try. For less than $0.25, it shouldn't break the bank to have an extra resistor. If you end up not using the 150 Ohm resistor, it can always come in handy for later PSU projects - particularly cheap PSUs that have very big load resistors on the output that cook the caps.
Looks alright, but I do have some suggestions:
For the Teapo SEK 10uF/50V, instead of going with Nichicon VZ (which is a general purpose cap), you can go with Rubycon YXJ (Digikey part number 1189-2322-ND). For the small caps, matching ripple current and ESR hardly matters, so it's just better to go with low ESR caps with higher ripple current. That said, Rubycon YXJ is just entry level low ESR, so it's perfect. And if offers much longer endurance life over Nichicon VZ.
Likewise, I see a Teapo SEK 470uF/16V on your list getting replaced with a Rubycon PX. Again, instead of going with a general purpose 105C rated cap, you can easily go with the Nichicon PW 470uF/25V choice that you have as a replacement for Teapo SX.
Then there's the G-Luxon SM 1uF/50V... no need to go with Chemicon KMG. Nichicon PW (Digikey part number 493-1887-ND) should be better.
And finally, the Teapo SH 1000uF/16V cap - looks like that one was on the 12V rail on the PSU. I would definitely suggest to increase that capacitance to 1200 uF or even 1500 uF. A lot of older low-end PSUs tend to cheap out on the 12V rail caps and use just one 1000 uF cap, which is quite minimalistic. And again, there's little reason to go with Nichicon VZ here, as PSU outputs are usually better suited towards low ESR capacitors than general purpose. So Here is a list of alternative cap choices you can go with:
Rubycon YXJ 1000uF/16V, Digikey P/N: 1189-1545-1-ND
Panasonic FC 1200uF/16V, Digikey P/N: P11204-ND
Chemicon LXZ 1200uF/16V, Digikey P/N: 565-1934-ND
Chemicon KY 1200uF/16V, Digikey P/N: 565-1529-ND
Rubycon YXG 1200uF/16V, Digikey P/N: 1189-1136-ND
Nichicon PW 1500uF/16V, Digikey P/N: 493-1793-ND
Chemicon KY 1500uF/16V, Digikey P/N: 565-1530-ND
Also, no need to replace that Rubycon YXF that was next to the PWM controller, as it is probably okay. Doesn't seem like it got heat-abused or anything like that. But if you don't have an ESR or capacitance meter, then I suppose you should replace it jut for the peace of mind.
Originally posted by ckrtech
View Post
View Post
