Hi, a faulty Dell XPS720 PC.
The power supply powers the motherboard on and gives a green motherboard LED but the motherboard is a no boot and no bios, just a black screen and components are A ok.
No beeps, no PC LEDs light up.
The capacitors in the PSU and on the motherboard all look ok.
I checked all the PSU solder joints and may have found one or two cold solder joints so re soldered them.
When I was checking the PSU solder points I saw what seemed like two messy solder joints. I removed the solder from one and found a white board marking under where the solder was and it is a boundary line for solder.
In the two photos the first shows almost all the white line between the two points that were soldered. The second photo shows the second place where I am quite sure same kind of components are used and a same white line exists beneath the solder - but with this second soldered point I am having an especially hard time removing the old solder.
Can anyone tell me whether the two points in question that have the white line beneath the solder(100% sure there is a white line beneath the second) should have been soldered?
It seems logical that if one of the two soldered points of two same components is soldered and the other two same components is not soldered then there may be a mistake. The odd soldering appearance that attracted me to these two same components soldered points makes me think there may be a mistake, maybe someone did this aftermarket.
I do not understand why the motherboard will not boot but I am prepared to replace the larger motherboard capacitors.
Also, I am not sure if I should replace any PSU or motherboard capacitors at this point either but seems a logical step for repairing and I may have found a PSU dell connector pinout for testing the power supply, which is an exciting step for me to have made I am pleased to say.
Not sure why the pictures are out of focus.
