Eeprom dump thread!
This is a sticky topic.
    Re: Eeprom dump thread!
    Hi! I need the dumps for a cheap Trevi TV.
    Model DTV-2522CI
    Main HK-7050-CI-V3.04-B
    Panel M215HW01
    Don't actually care if it's Trevi branded or not, I just care if it works for watching TV.
    Thank you
    Davide
      Originally posted by retrocomputer View Post
      hi! I need the dumps for a cheap trevi tv.
      Model dtv-2522ci
      main hk-7050-ci-v3.04-b
      panel m215hw01
      don't actually care if it's trevi branded or not, i just care if it works for watching tv.
      Thank you
      davide
      Токаї ltl-1902e hk-7050-ci-v3.04-b
        First of all, thank you so much!!
        There's just one thing bothering me... The dumps you sent me are from a 19" TV, whereas mine has a 22" panel. Is it ok anyway?
        Thank you
        Davide
          Hi..
          I'm looking for firmware for a JVC 50 inch led tv...I don't have a number but a board number
          Chassis:Jug7.820.1222
          Cpu. :MSD6328 BXA-Z1
          Panel. :T546hb01
          54T07-c02
          Any help will be appreciated
            Anyone have this file
              Unlikely to get a response where the model number of the TV is omitted.
                Thank you
                Davide
                No ideas about this? Or the best thing is just to try?
                Thanks!
                  Thanks!
                  Try, only save your dumps. First try spi flash (EN25F80) to check
                  Here is another 22
                    Thank you
                    Davide
                    if resolution is same than it will work.some settings like mapping may be needed in service menu
                      Thanks a lot
                        Re: nevir :nvr-7409-43hd-n
                        good night
                        does anyone have the dump of this tv,
                        main board: tp.s506.pb801
                        display: HV430FHB-N40
                        the TV only changes the color of the LED monitor, from red off to green on, and the only thing that does
                        thanks to anyone who can help even with an idea
                        thanks.
                        Last edited by SMDFlea; 09-20-2021, 07:12 AM. Reason: https://translate.google.com
                          Anyone has Sony 65W850C dump file?
                            Originally posted by Amazig View Post
                            boa noite
                            alguém tem o dump de este tv,
                            placa principal : tp.s506.pb801
                            display : HV430FHB-N40
                            o televisor só muda da cor de led monitor ,de vermelho desligado ao verde ligado, e a única coisa que faz
                            obrigado a quem pode ajudar mesmo com uma ideia
                            obrigado.
                            check back light
                            verifique a luz de fundo (google translation)
                              Hello
                              thank you rajnhl; I've already checked the bottom leds; everything working; now an information; I received the bin file to update via usb, will it be possible to record on the chip, because the tv does not turn on!
                              thanks
                                Hi does anyone have firmware for RTU6549-MAIN-V2 RCA Main Board, CV3458H-A, 7.T3458HA1000.0008
                                I got a Version 1 CV3458H-A, 7.T3458HA1000.0003 off ebay for 30.00 and popped it in and board works but about every 20 or 30 minutes tv loses input signal and have to flip HDMI source than back to get picture up again. Probably from not being the same board as original which has lost its HDMI port signals won't work.
                                They are practically identical. Anyone know if I flash the 7.T3458HA1000.0003 board with the 7.T3458HA1000.0008 firmware should work? Thanks for any help.
                                Board BD_CV3458H_A_10
                                Panel LC650RU1A
                                  I need dump file for Sony 65W850C please.
                                    Hello
                                    thanks
                                    plug usb drive and connect to power .
                                      Hi..
                                      I'm looking for firmware for a CHANGHONG LED55A4000 55 inch led tv...
                                      CHANGHONG LED55A4000,
                                      Panel. :T546hb01
                                      54T07-c02
                                        Hi..
                                        Panel. :T546hb01
                                        54T07-c02
                                        Post a picture from the back of your tv.
                                          Ok Ducky29
