If the voltage at the capacitors was 172V & PS_On was ON (3.5v) then it looks as though the PFC circuit (L6599) is not running.
Taking great care, with the black meter lead on the -ve leg of EC1 and the red meter lead on pin 12 of the L6599 and the set out of standby what dc voltage do you have on that pin. It needs to be a minimum of 10.7V
What order are the pins? Which one would be 12?
I'm guessing you say to take great care because of the difficulty of probing on opposite sides of the board?
Check if the IC has a dimple close to pin 1. Cannot make it out from the photo above and refer to attached pinout.
With the mainboard disconnected and any jumpers in place, turn the power supply board over and rest carefully with the power supply resting on an insulated surface so that nothing can short out.
You need to take care because of the voltages and also not to short any pins out on the L6599.
If your meter probe is to thick to place carefully on pin 12 then tape a needle securely on the probe tip and you can then use the needle point to test pin12.
Ok, so at this point the only connector that should be plugged in is the AC power, correct? I don't have to turn the set on for this check?
I can see from your replies that you are not familiar with testing.
However did you check the diode D4 as suggested by Budm post #43.
Unsolder one end of the diode and lift it clear of the circuit board. With your meter set to diode mode check across the diode. This test is done with the set disconnected from the mains.
You are correct! I have some experience, but very limited if that makes sense. I'm just trying to be certain that i don't have connectors plugged in when they shouldn't be. When you say "disconnected from the mains, you are saying NOT to have power to the board, am i right?
I haven't checked the D4 diode or Pin 12 yet as i am currently not at home. I'm just trying to be certain that I'll know exactly what to do when i am back in front of the set.
So this diode need to be replaced then.. What type of diode am i going to be looking for as far as replacement? I have never replaced one before but i have plenty of experience with capacitors and soldering.
I have a huge bag of caps and diodes, but none with this same number. I read something about being able to use higher rated diodes in place, but I'm not sure if that's true. I did find one that is the same size, but with different numbers on it. It is "IN5408 222" Would it possibly work?
