Hello. Got my hands on Philips 47pfl6008s/12.
Problem is that it does not turn on. Last owner said the problem came slowly.
One day did not respond to remote, had to unplug from AC and then back and it worked. next day had to disconnect 3-4 times before it turned on.
And then it went into hours of unplugging and replugging until it turned on.
When I plug AC into tv, it does not respond to "turn on" button or anything else.
After 10-15minutes the TV starts blinking red LED twice.
So it blinks twice, then waits 3 seconds, then again twice and waits....
So its in some kind of protection mode?
I myself managed to turn the TV on once. it worked about 30minutes until random "white noise" lines appeared and the TV became unresponsive. Few minutes later it turned off and no response anymore. Led blinks twice but cannot get it to turn on anymore.
I have disassembled the TV and replaced every electrolytic capacitor with same capacity but littlebit bigger voltage. So if stock cap was 24v 440uf, I replaced with 50v 440uf.
And yes... replaced all I found...
I found 3.4v on the board and 12v.
Is there 5v somewhere also? Did not found it anywhere.
from the "ribbon" cable that goes from PSU to Motherboard. there was no 5v text on the pcb if I remember correctly.
I know something about electronics and I am not afraid to disassemble it or replace SMD components.
But I have no idea what I am looking for.
