Hi guys can somebody help me and clean or fix my bios for Dell XPS 13 9365 - LA-D781P. When i switch on the laptop it shows the backlight keyboard for roughly 3 seconds and turn off. Service tag is 627JHR2. Here it the original dump
Dell XPS 13 9365 - LA-D781P bios
Re: Dell XPS 13 9365 - LA-D781P bios
Originally posted by Stunt View PostHi guys can somebody help me and clean or fix my bios for Dell XPS 13 9365 - LA-D781P. When i switch on the laptop it shows the backlight keyboard for roughly 3 seconds and turn off. Service tag is 627JHR2. Here it the original dump
Originally posted by dst30648487 View PostPlease need help clear me region Xps 13 9365..
Next time you can follow the steps in that Guide and do if by yourself.
https://www.badcaps.net/forum/showthread.php?t=88533Attached Files----------------------------------------------------------------------------------------------------------------------------------------------------------------------
all donations are welcome,
>>>>> click on this link to donate via PayPal. <<<<<
Originally posted by Lightcap View PostHI,
I have this problem also. What programmer would i need to read the bios chip, also i'm guessing the IC has to be removed from the board to read it.
BIOS guides, methods, resources and tools
Become a Badcaps supporter
Thanks to all supporters.​
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..
Hi., can anyone help me clean this Dell XPS BIOS for me. The motherboard turn on, take the required amps 0.33 ~ 0.48amp). 3.3V $ 5v are all good. I get +VCC_CORE & +VCC_SA, but +VCC_GT is missing. & after about 20 sec approx. the motherboard stops working & CPU Cools down. I checked the voltages on Memory chips rail, all are fine. Maybe a cleanup might rectify this problem. Service Tag # 6TNZ4S2. Thanks in advance.Last edited by mferna14; 05-23-2023, 03:13 PM.
Originally posted by mferna14 View PostHi., can anyone help me clean this Dell XPS BIOS for me. The motherboard turn on, take the required amps 0.33 ~ 0.48amp). 3.3V $ 5v are all good. I get +VCC_CORE & +VCC_SA, but +VCC_GT is missing. & after about 20 sec approx. the motherboard stops working & CPU Cools down. I checked the voltages on Memory chips rail, all are fine. Maybe a cleanup might rectify this problem. Service Tag # 6TNZ4S2. Thanks in advance.Attached Files----------------------------------------------------------------------------------------------------------------------------------------------------------------------
Originally posted by TipSerw View PostHi, I have a problem with cleaning ME Region for my Dell XPS 9365. There are errors in Flash Image Tool. Can you try to clean ME Region on my dump? There is problem with TPM error.
