I have this amplifier in the workshop that burns the fuse when I turn it on. What is the procedure to follow since something is short?.Thanks
Technics su-z960 burnt fuse
Re: Technics su-z960 burnt fuse
Service manual:Attached FilesNever stop learning
Queer enough, I just encountered the same problem. I was quite astonished to find the problem in a shorted foil condenser (C702 in the schematic). There are alternative values, mine was a 220nF, 100V type - not enough for the AC peak value of 120V across the condenser. Another source of failure might be the hybrid power amp (IC501, SVI3105B).
Good luck on your repair!
