Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting TVs and Video Sources
Thread Tools Display Modes
Old 05-21-2019, 01:49 PM   #1
imaddicted2u
City & State: Sydney, Nova Scotia
My Country: Canada
I'm a: Knowledge Seeker
Default Lg 32ln570b
Bought this 32" 32LN570B for $20. Had no backlights. I replaced 2 failed LEDs on one of the 3 strips.
Most of the lenses over the LEDs had fallen off and I ended up taking off the others off to test the LEDs. They were very brittle. I had to glue them back on the strip.
I have no idea what the display looked like before I bought it but this is what the backlights look like...It looks like some of the LEDs are glowing more brightly than others. The blotches are not as noticeable when watching a normal pic. Still worth 20 bucks...lol.
The backlight was set to 100%, I set it down as low as I could, around 30%.
Anyone ever see this before?
imaddicted2u is offline   Reply With Quote
Old 05-21-2019, 02:03 PM   #2
nomoresonys
City & State: midwest
My Country: U.S.
Default Re: Lg 32ln570b
A couple threads lately, see if I can find m.
nomoresonys is online now   Reply With Quote
Old 05-21-2019, 02:05 PM   #3
nomoresonys
My Country: U.S.
https://www.badcaps.net/forum/showth...ight=ring+leds
Old 05-21-2019, 02:20 PM   #4
nomoresonys
My Country: U.S.
https://www.badcaps.net/forum/showth...t+spots+screen
Old 05-21-2019, 02:39 PM   #5
diif
City & State: Midlands
My Country: England
I'm a: Professional Tech
You haven't aligned the lenses correctly.
diif is offline   Reply With Quote
Old 05-21-2019, 03:31 PM   #6
nomoresonys
My Country: U.S.
Check those 2 threads, some good direction on proper positioning of lenses.
Old 05-21-2019, 05:32 PM   #7
imaddicted2u
My Country: Canada
Didn't know the lenses needed alignment. Thanks I'll check the links for details.
Old 05-21-2019, 05:57 PM   #8
neilc6
City & State: BC
My Country: Canada
Are these the thick style lenses? I use 5 second fix, glue them with the leds on to make sure they are perfectly centered, put diffuser back temporarily to check, and then uv cure if they are ok.
neilc6 is offline   Reply With Quote
Old 05-21-2019, 09:26 PM   #9
yokoono
Cut squares of 4/4 cm matt plastic (from another TV) and stick directly on defocused lenses. Otherwise it is hard to focus.
yokoono is offline   Reply With Quote
Old 05-22-2019, 05:49 AM   #10
imaddicted2u
My Country: Canada
Quote:
Yes, thick cut lenses. Funny I just watched a video doing exactly what you suggest...lol. I read some threads discussing the difficulty of getting the lenses focused correctly.
Wouldn't you know this would be the time I didn't document everything with pics. Now I wish I knew the part numbers of the strips. I know there are 7 LEDs per strip. I'm finding sets of 3 on ebay for about $20 so I might just buy a set. I see various combinations marked A1, A2, B1, B2 strips. What's the difference between them and how critical is it to get the combo right? I sent the TVs service code number to LG asking for part numbers but I find most companies aren't very good at responding to their online forms.
Old 05-22-2019, 06:49 AM   #11
Andrew F. Ali
Andrew F. Ali's Avatar
City & State: Point Fortin
My Country: Trinidad & Tobago
Line Voltage: 125VAC 60Hz
You should replace the 3 existing LED strips with new strips. Problem solved.
Andrew F. Ali is offline   Reply With Quote
Old 05-22-2019, 07:10 AM   #12
neilc6
City & State: BC
My Country: Canada
I recently encountered a 50LN5310 that used these thicker lenses with 3V LEDs. Shopjimmy indicated two different panels and this one was a Heesung panel. Only one LED was shorted but a lot of lenses were about to fall off. In hindsight, I should have reglued them right away matching both lens and orientation but had to redo them a second time because of bright spots. Also, it is better to reflow the LED without removing the strip since it is difficult to remove without popping off every lens.
This may be your part if you want to replace all the strips. https://ebay.us/yUmDa8 or https://ebay.us/8dC46e
Old 05-22-2019, 03:22 PM   #13
imaddicted2u
My Country: Canada
I took the panel apart again. The glue is stuck real good, lol, not much point trying to align them so I'll replace the strips. I thought there were 3 strips with 7 leds. Actually there are two with six (type A) and one with seven (type B) leds.
neilc6, thanks for the links. Looks like the ones I have. Going to order a set, Problem solved.
Here are a couple of pics...
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2019
Powered by vBulletin ®
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
