Good day folks. I'm trying to figure out what's wrong with this power supply. It's from a barebone PC/POS thingy, NVM. It's supposed to be on all the times: just a single output - no ON/OFF control or anything. I tracked the problem down to the two control ICs on the back not receiving the correct supply. They're an NCP1605 (U100 on the left, for PFC I reckon) and L6599 (U300 on the right) for the main switching action....the VCC pins are common and get around 7v, which is not enough. I tracked VCC down to Q304 of which I took a close-up....DQ QZ....what could this be ? Could it be one of THESE ? At the bottom we have 2SD2211. The package and pin layout corresponds and would technically make sense: the VCC pins go to the left terminal (bottom one in the picture - the emitter, "output" let's call it) and then the tab (center contact) goes to those diodes, which would make it the "input" collector. The remaining pin (top one), is connected to that zener diode and the top optocoupler, so that would be the base.
Now the VCC for those IC (and therefore the bottom pin of the IC) jumps around between 7v and 14v, like it's trying to start up but fails. Measuring those two diodes (D309 and D308) gives me 7v, which I'm not sure is enough.
No schematic and a truck load of SMDs....it's like tough sh!t It's be really awesome if we could get it going.....any ideas ? Cheers and thanks. No blown stuff on the board BTW, of course....
