hp workstation x4000 fuh yin?
    this is a tyan dual xeon in a hp x4000
    these were found on the memory board.
    good reason for the frequent bsod problem.
    Re: hp workstation x4000 fuh yin?
    what more brands? that badcaps list is looking to be a chore.
    http://www.fuhyin.com.tw/english/index-e.htm
    Standard Aluminum Electrolytic Capacitors are not suitable for rapid charge and discharge applications. Consult with Ltec about specially designed capacitors for rapid charge and discharge
    what is their connection with Ltec then.
      FUH YIN has a very poorly designed website. They also have many mistakes in their English too on their website.
      willawake, is FUH YIN going on the list of bad cap brands?
      My gaming PC:
      AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
      ASUS M4A77TD AMD 770 AM3 Motherboard
      PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
      G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
      TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
      WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
      ASUS Xonar DG 5.1 Channel PCI sound card
      Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
      Antec Three Hundred Mid-Tower Case
      Microsoft Windows 10 Pro 64-bit
      Microsoft Windows 7 Ultimate SP1 64-bit
        done already.
        reminds me of FOOK HING chinese restaurant amsterdam
          Fook Hing has mushroom caps.
          Jim
            I just purchased two of these HP X4000 units and from what I'm reading, I think I know why I got them so cheap!
            I noticed on both systems that the caps on the memory board (the same exact ones that you have in your hand) have bloated tops and some of the material from inside has pushed up thru the top. One in particular had a large chunk of white crust on top. Before I go and finish building up these units... what am I looking at here? What should I do about these caps? I'm not an electronics guy so can I have these replaced pretty inexpensively and what caps do I need?
            Sorry for so many questions... I want to make sure these systems are repaired if that's what needs to happen.
            Thanks in advance for any good advice.
              change those caps.
              the rest were rubycon or nichicon on the 5 units i have had in for repair.
                Could you tell me what you replaced those bad ones with? Same ratings, type, size, etc? I see an earlier comment about "not suitable for rapid charge and discharge". Did you go with anything different other than brand?
                Thanks.
                  1000 10v? replace them with 1000 6.3 or 10v from the good caps list section 3 of the faq. try to find 8mm width for convenient placement
                  https://www.badcaps.net/forum/showthread.php?t=425
