Just when I swore I'd never fix another TV, this monster plasma found it's way to my door. It's the classic power cycling, clicking relay, no picture kind of failure you guys love to figure out!
Threads for reference:
https://www.badcaps.net/forum/showthread.php?t=29327
https://www.badcaps.net/forum/showthread.php?t=27535
The curve ball with this set is that it could be anything, allow me to explain why.....
When I removed the back panel, the connector going to the front panel was disconnected from the main board, along with the speaker connection. Someone was definitely in there, making this my least favorite kind of repair, who knows what they did? Referring to the threads above, I began trying to pinpoint what had failed. When the set has power before cutting off, VS and VA are there(202 & 55). I disconnected the X and Y mains one at a time hoping for a change. Nothing, still clicking. Next up would be the main/logic board. Not having any of the correct value resistors to force power on without the main board, I had to get creative.(Don't judge me, it's not like I can go Radioshack anymore!)
When I Plugged in the set with the resistors in place, it powered up without clicking( LVDS and power connector from the main board were removed). No grey flicker or any sign of life from the panel. I jumped pins 3 & 4 on the logic board and crossed my fingers, but no test pattern was displayed. I decided to look over the SUS boards one more time to see if there was anything I missed. To my horror, I discovered that two transistors and 2 zener diodes had been removed from the Y board!
Now I'm at a loss because I have no idea what kind of repair was attempted. In a desperate attempt to make some kind of progress with this set, I pulled a similar samsung Y board from my graveyard, removed what I hope are the same value transistors and diodes, and soldered them on.
With the Frankenstein Y board back in the set, I repeated the panel test. This time whether or not the logic board was jumped, I got a grey flicker on the panel after power up, followed by grey snow at the top of the screen that slowly faded away. The panel does glow for a short time, then cuts off to black. I wouldn't mind throwing another main board in there since that seems to be the culprit, but the lack of a successful panel test has me weary. Could it be the logic board, the main board, all boards?
Help me O wise badcap veterans, you're my only hope!
