Samsung plasma PN58B650S1F clicking relay no picture
  • MyEvolution
    • Apr 2012
    • 23
    Evening all,
    My name is David & am working on diagnosing a Samsung PN58B650 that won't turn on. I received this TV from a friend for free after it died. I'd like to trouble shoot the issue & replace either the culprit board or component if I'm capable. I have diagnosed & repaired a HP PL4260N with a bad y-sustain board so am not a complete noob to this stuff.
    Here are the symptoms & what I have tried so far:
    Upon plugging in the TV, a red readiness light is present on the front, turn the unit on either by the touch pad on the TV or the remote & it goes into looping click on/click off cycle. Once this takes place, I have to unplug the TV to power down as the remote & pad become unresponsive. I have ohm tested all the fuses & found them to be good. Unplugging individual boards as follows continue the clicking cycle: y-sus, x-sus, logic or control? Once I unplug the tuner board the unit becomes completely unresponsive, ei will not power up into the clicking cycle. This is if I unplug the power to said board or the harness at the bottom right corner. I tried jumping the #3 & 4 pins on the logic or control? board to get a picture to no avail. Still click cycles, no response on screen.
    I have reached my limit of knowledge of trouble shooting & need assistance please
    Re: Samsung plasma PN58B650S1F clicking relay no picture
    When you jumper pins 3-4 have you also disconnected LVDS, and on some sets forced the power supply ON?
    • MyEvolution
      • Apr 2012
      • 23
      From reading your previous posts about jumping the pin, I assumed the cable in question is one going to the tuner board. I did remove the harness from the control and/or logic board that leads to said board. I also saw a post where you asked if the TV had a PS ON and to insert resistors into the harness on the main power supply board so I was not certain that I need to do the same. Figured I may not be doing the procedure correctly.
      What I really did not expect was upon disconnecting the tuner board from the power supply the TV would become completely unresponsive. I assume either the TV will not power on at all without the tuner board connected or that the tuner board is in fact somehow the problem.
      • cashkennedy
        • Aug 2011
        • 668
        LVDS cable is running between tcon and tuner, it leaves the top of the tuner board and is a flat ribbon cable.
        You will need to try to turn the set on manually using the resistor technique most likely from something like 5v to pson. both located on the power cords running from the power supply to the tuner board.
        Fixed so far 12 lcd's , 1 plasmas, 5 monitors, 0 dlp's (plan to keep the dlps at 0). and 3 atx power supplies, and 2 motherboards.
        • MyEvolution
          • Apr 2012
          • 23
          That's the cable I unplugged, so, yes, I'll have to do the resistor jump then. In the post I read previously by you tom66, you had the guy use 2 resistors;
          Quote from this thread:
          https://www.badcaps.net/forum/showth...samsung+plasma
          " Connect whichever value is your favourite from PS-ON to GND, and one from VS-ON to GND. Check if Vs/Va appear and if 5V etc appear."
          Should I do the same?
            Yes, except I later corrected my error and it should be PS-ON to GND, VS-ON to 5V.
            • MyEvolution
              • Apr 2012
              • 23
              Very well then. I'll go pick up some resistors from Radio Shack & report back. Thanx
              • MyEvolution
                • Apr 2012
                • 23
                Ok, have the resistors. Want to make sure I'm following instructions correctly. I unplug harness from power supply to tuner board & apply the resistors to the harness going to the logic board as pictured on top of page 2 of referenced thread?
                • MyEvolution
                  • Apr 2012
                  • 23
                  Like so?
                  • MyEvolution
                    • Apr 2012
                    • 23
                    Update: plugged TV in with above format of tuner board harness unplugged, resistors in place as pictured, observed grey screen that went away quickly ( no screen activity previous to this point), found green light flashing on logic board, tested vs, va, & 5v, all good. Now onto jumping the pins...
                    • cashkennedy
                      • Aug 2011
                      • 668
                      Looks good to me, although im confused why they have vson and pson on both the tuner power conector and on the tcon power connector. It should be safe though for you to start it. If the set doesn't work you could try it with the resistors on the connector going to the tuner board.
                        If the logic board on these isn't jumped and it doesn't detect active LVDS it'll turn off the VSON. The 3-4 jumper causes it to run independent of the main board, as long as PSON and VSON are properly pulled down/up.
                        • MyEvolution
                          • Apr 2012
                          • 23
                          Update: jumping pins produces test patterns, beautiful test patterns!!! Now what?
                          ps: tried to upload a video from my iphone but it didn't work?
                            Probabilities of a particular failure
                            Your main board is at fault: 95%.
                            Your logic board is at fault: 5%.
                            Therefore, replace the main board.
                            For videos, use youtube or similar video sharing sites.
                            • MyEvolution
                              • Apr 2012
                              • 23
                              K, I'll report back asap. Tell me again which # I order by?
                                BN96-xxxxxxx or LJ9x-xxxxxxx only
                                • MyEvolution
                                  • Apr 2012
                                  • 23
                                  btw, you guys, YOU GUYS...
                                    Looks like it's BN94-xxxxxx on this one, but don't use the BN44 whatever you do...
                                    • MyEvolution
                                      • Apr 2012
                                      • 23
                                      Found a BN97 # under the white sticker & on the back of the board
                                      • MyEvolution
                                        • Apr 2012
                                        • 23
                                        Update: received the new tuner board this afternoon, installed, & BANG!, we have a perfectly working 58" plasma!!! All I need now is a stand. Thanks guys. I appreciate the help & technical expertise...
                                          09-07-2024, 05:50 AM
                                        • Journey11
                                          Samsung TV won't turn on ... keeps cycling the power relay on & off
                                          by Journey11
                                          Hi All,
                                          First time posting here ... my name is Kevin but my friends call me Journey.
                                          I have a Samsung 75" LCD model UN75RU8000FXZA that I don't remember the original fault other than it wouldn't power up anymore.
                                          After it sat for many month's I decide to look at it again. The motherboard seemed to have power regulation issues. After much fussing I decided to just get a new MB.
                                          It came a few days ago and I installed it now just cycles the power relay on and off ... when on the backlights light up and then dim and then relay kicks off and the whole things starts again....
                                          07-04-2024, 02:44 PM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
