Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Desktop Motherboards, Graphics Cards, and PC Peripherals
Thread Tools Display Modes
Old 07-14-2017, 11:51 AM   #1
TheQuentincc
City & State: France
My Country: France
I'm a: Knowledge Seeker
Default MSI Z77A-G45 SMD caps dead
Hi, I have the 2nd PCIE x16 of my MSI Z77A-G45 not working, below it I can see a SMD capacitor which is burned, I can fix that but I don't know what capacitor use, should I use random caps with the same size ?
Here the capacitor (just below the "SFC" thing)
Thanks for help :jap:
File Type: jpg 1857f9ced3d035d5e2aec13388c63fe637837f69.jpg (857.3 KB, 27 views)
Last edited by Per Hansson; 07-16-2017 at 02:21 AM.. Reason: Offsite image uploaded
TheQuentincc is offline   Reply With Quote
Old 07-16-2017, 12:16 AM   #2
momaka
master hoarder
momaka's Avatar
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
I'm a: Hobbyist Tech
Default Re: MSI Z77A-G45 SMD caps dead
That "SFC" thing is a coil/inductor. So there might be a buck regulator in that area, which is what the ceramic cap could belong to.
That said, I don't see the burned ceramic cap in your photo, so it is hard to say what to use.
I used to do the "replace with similar size" for ceramic caps a few years back when I didn't have a capacitance meter, and I've never had it not work. (To say it another way, I've had good success with that method).
Old 07-16-2017, 02:20 AM   #3
Per Hansson
Per Hansson's Avatar
City & State: ----
My Country: Sweden
Line Voltage: 230v 50Hz
Quote:
Look at the lower left of the SFC inductor, where it's PCB outline is.
__________________
Per Hansson is offline   Reply With Quote
Old 07-16-2017, 06:58 PM   #4
momaka
master hoarder
momaka's Avatar
My Country: U.S.A.
Ah, I see it now. Had to zoom in the picture.
I suppose the O/P should take it out and see if it is shorted or if there is something else going on.
Would also be helpful to do a little tracing. Is the ceramic cap's function related to filtering power or signal? Is one side of the ceramic cap connected to ground? Is the other connected to voltage rail? Regulated or directly to PSU? That should give us a clue to what the cap might be doing and how critical it would be to get something with the similar specs or just wing it (and use a cap of similar size).
Old 07-19-2017, 08:22 AM   #5
cpt.charlie
City & State: Torrelavega
My Country: Spain
Line Voltage: 230VAC 50Hz
It doesn't look like a capacitor to me, maybe it's a 0402 resistor or inductor, is it connected to ground?.
cpt.charlie is offline   Reply With Quote
Old 07-19-2017, 11:05 PM   #6
Th3_uN1Qu3
Believe in
City & State: Bucharest
My Country: Romania
I'm a: Professional Tech
No i think it is a cap, likely in parallel with the larger one next to it. Not a real problem to just leave it out...
__________________
Quote:
Originally Posted by PeteS in CA View Post
A working TV? How boring!
Th3_uN1Qu3 is offline   Reply With Quote
Old 11-06-2019, 04:07 AM   #7
manana2019
City & State: melaka
My Country: malaysia
Line Voltage: 240vac 60hz
Hai ,I have m/b msi Z77A-GD65 but having problem on/off power when start button is press.checked the ram voltage 1.5 and 0.075 ok.can someone support the schematics diagram.
Thanks so much.
manana2019 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums © 2003 - 2021
Powered by vBulletin ®
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
