Good day folks. Having messed with power supplies a lot, getting shocked and whatnot and constantly trying to improve my knowledge of them, I was wondering: what exactly gives the output power figure of a SMPS, let's say a wall-wart or power pack for a laptop for instance. Every power supply out there has a wattage stated on it in W, so what exactly gives this upper threshold ? There's also a current rating stated, so basically the power is the rated voltage, times the maximum current, so since we can't alter the voltage, we want to increase the current capacity.
We know SMPSs contain several blocks, so is it the switching block (the FETs), or the rectifier block that's the bottleneck? What should be upgraded with components of higher specs to increase the power of a SMPS or at least make it more reliable after it blew and you fixed it ? The FETs, the diodes, the coil, or a combination of these perhaps ? When replacing trannies, I always choose ones higher up the range in that family for instance, so if the original was a MJE13003, I'd got with a 13009, even though these are not FETs...just a random example. Cheers guys.
