NovaTek EasyWriter
    NovaTek EasyWriter
    I need this software to first, get the firmware image and
    then to reprogram a new NovaTek NT68F63L in a Samsung SyncMaster 913N
    I have the logic problem as described in;
    https://www.badcaps.net/forum/showth...t=samsung+913N
    Thanks in advance
    Re: NovaTek EasyWriter
    i know this is ancient, but i have the same problem, the 47ohm bridging worked for like a year, now thinking of changing the chip. so, bump!
      I think it'd be better if you buy the new chip. It's not expensive.
      Novatek nt68f63lg http://www.ebay.com/itm/1-pcs-NOVATE...item415ec83896
        yes, this is what i'm planning, but i can only find empty ones, i need to find a way to program it too, and i have absolutely no experience on the matter. elsewhere on this forum a person said that all i need is a LPT > VGA cable and after some reading it seems it means the chip supports In-Sytem Programming but i need a confirmation. Also, that cable is not easy to find so i was thinking since most of the pins are reserved maybe i just need to connect two or three wires, like pin 12 on the vga and some ground, but to what pins on the parallel port?
          Hi, did you managet to get firmware and software.
          I need to flash IC, please help
          ...the quieter you become the more you are able to hear...
