SAMSUNG led un32eh4003f Plays melody No picture & led blink
    Re: SAMSUNG led un32eh4003f Plays melody No picture & led blink
    Good, we just have to verify that.
    Did this low lights problem happen all the suddenly?
    BTW, did you already try reseating the connectors on the LED strip.
      "What should the voltage be on pins 1/2 and 4/5? I get 22.4 V on each set with pin1 to chassis - 152V, Pin 2 - 129V, pin 4 - 129V and pin 5 - 107V." I do not quite understand you measurement as to the reading of all the pins, is it against GND?
      "with pin1 to chassis - 152V" So the measurement is made between pin 1 (red probe) and GND (Black probe)?
      "and pin 5 - 107V" Is it also between pin 5 and GND?
      Disconnect the LED CABLE and take the reading again between pin 1 and GND to see if it is >200VDC.
      • keithwyatt533
        • Jun 2015
        • 5
        Voltage readings were taken between Gnd and each pin. I also took the voltage reading between pins 1 and 2 - 22.4V and pins 4 and 5 - 22.4 v. This is a brand new TV that has been sitting in storage long enough for the warranty to run out!
        Disconnecting the LED cable seems to shut down the voltage to that connector. I do read 176V on pin 1 but it slowly discharges a cap and by the time I check the other pins they are at 0V.
          OK, so from what I see is that the Voltage drops on each string is only about 23V, 152V - 129V = 23V, 129V - 107 = 22V.
          mangus580 was getting 211V (open circuit, and you get 176V) so your boosted Voltage is low based on your measurement.
          So we need to do more in depth troubleshooting.
          This is your board, right?
          http://www.shopjimmy.com/samsung-bn4...led-board.htm#
          BTW, how many LEDs are there total?
          • keithwyatt533
            • Jun 2015
            • 5
            Yes, that is my board. There are two LED strips each with 9 LEDs.
              So it has 18 LEDs total, 3.5V x 18 LEDs = 63V, 63V /2 = 31.5V Vdrops per strip and you are getting about 22~23V.
              • keithwyatt533
                • Jun 2015
                • 5
                Power Supply board is definitely bad. Checked another one and the voltage across each LED array varies from 20V with back-light set to 0 to 105V with back-light set to maximum of 20.
                • Caleb
                  Smokin IC's
                  • Feb 2013
                  • 645
                  Finally managed to fix mine today, replaced 7 leds, 5 were shorted out and 2 were open. I wrapped 24 gauge wire aroud the tips of my multi-meter and pushed them under the lenses on the sides to test each led. I then heated up the under side of the strip with the hot air wand until the lens came free from the bad ones. Then using the tip I read on badcaps I used a 100 watt iron and a big blob of solder under the led until it came loose. New (used) leds were harvested from a smashed apex I picked up yesterday. and reattached the same way, super glued the lenses back on after testing to make sure it would stay on.
                  Liberating magic smoke one part at a time
                  • chop sang
                    • Apr 2017
                    • 4
                    • Viet Nam
                    #49
                    troubleshooting Fet KN6N60 and IC 3S111 both of them broken. The power supply board is working now, the voltage out is normal 116VDC at D+,D- when measure with the chasis. When i plug in the power suply, the red light is On, and also has the sound starting ON. But the LED backlight is still blind, not working. I measure all the voltage in the large connection in the board power supply follow the table on the top layer. Every pins has normal voltage except one, this is Pin 6 different, when turn On/off it still 0 V. Could you please suggessted any idea for me right now, tks for help alot.
                    P/s: i have already checked the LEd strip backlight one by one, all LEd light still good ( checked by 3V battery and 100ohm)
                    • chop sang
                      • Apr 2017
                      • 4
                      • Viet Nam
                      #50
                      Please help me, i'm new member in this forum and i have same problem with myTivi samsu 32EH4003, the frist one, power supply board BN44-00664 is broken fuse, i have already solved bytroubleshooting Fet KN6N60 and IC 3S111 both of them broken. The power supply board is working now, the voltage out is normal 116VDC at D+,D- when measure with the chasis. When i plug in the power suply, the red light is On, and also has the sound starting ON. But the LED backlight is still blind, not working. I measure all the voltage in the large connection in the board power supply follow the table on the top layer. Every pins has normal voltage except one, this is Pin 6 different, when turn On/off it still 0 V. Could you please suggessted any idea for me right now, tks for help alot.
                      • chop sang
                        • Apr 2017
                        • 4
                        • Viet Nam
                        #51
                        up
                        • dick_barton
                          • Aug 2015
                          • 6643
                          • Wales
                          #52
                          If you disconnect the mainboard do the backlights come on and stay on.
                          If not what is the voltage at
                          D+, D-, S+ & S-
                          • chop sang
                            • Apr 2017
                            • 4
                            • Viet Nam
                            #53
                            D+, D-, S+ & S-
                            yep, thanks a lot. But, I think that my problem is not related with power supply board and backlights Led string now. Because untill now, i have already fixed power supply board, and the TV became normally except not picture. When I turned on/off, the Led light on the bottom display the same, meaning it's working normally. The backlight is the same, working still good. The only problem now is not picture, i think that display board (depicted on below) is not working now. Do you guys have any idea about this, waiting more helps from you guys.
                            • dskall
                              • Oct 2016
                              • 2905
                              • usa
                              #54
                              Need some pictures. Does this tv have a t-con board?
                              • thumper300zx
                                • Feb 2018
                                • 1
                                D+, D-, S+ & S-
                                I have this TV with the same power controller. LED backlight went out.
                                I get power on with 6 red blinks. I can see letters with flashlight test.
                                I tested and have full voltage between D+ and chassis.
                                Connected, I have a drop between D+ and S-. But get zero at D-. So, looks like I have one bad strip.
                                I removed black cable from S- and D- and plugged S- into D-. Turned on TV and it lit up. My understanding is this is too many LEDs to have omitted to keep running (too much power?). I've also read some people replace the LED s with Christmas lights, etc. Anyway, just thought I'd offer that up for anyone else troubleshooting.
                                  09-07-2024, 05:50 AM
                                • howardc64
                                  Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                                  by howardc64
                                  • Prior owner tried a replacement main board. No difference.
                                  • Samsung 2x red blinking standby LED = panel fault
                                  • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                                  • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                                  • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                                  07-19-2025, 10:54 PM
                                  09-06-2024, 11:40 PM
                                  09-06-2024, 08:40 PM
