ROG G512li No power
  • Zparts01
    • Nov 2021
    • 107
    Re: ROG G512li No power
    Mon2, I was able to check the voltage on the bridge board is 1.8v. I have attached 2 photos, One show the full chip markings on the top and the other shows the chip mounted onto the adapter board that I then plug into the 1.8v bridge board, then into the CH341A. If I plug the adapter board with the chip on it directly into the CH341A it detects the exact chip, but says it's a 1.8v chip. Very strange.
    • mon2
      • Dec 2019
      • 14662
      The flash device is indeed a 1v8 rated part.
      • Zparts01
        • Nov 2021
        • 107
        Thanks Mon2! I'm just confused as to why it won't work in the bridge board, but works straight up in the CH341A where it can be read perfectly. Could it have been damaged in some way?
        • mon2
          • Dec 2019
          • 14662
          According to the datasheet and part number decoder, this device cannot handle a high voltage on the Vcc rail such as 3v3. That is beyond the max rating.
          If the low voltage bridge board is functional with other parts you have used in the past then can only conclude that this flash device is not stable to operate @ 1v8.
          You can try it but best to seek out a replacement of the same part. Grab a few. Check the fresh stock on the bridge board that operates @ 1v8. Does it work? Continue to flash your contents and verify again at 1v8.
          Finally apply onto your board.
          • Zparts01
            • Nov 2021
            • 107
            That makes sense to me for sure. I will order some new chips and see if I have any issues using the bridge board. I'll let you know once I have done that. Thanks!
            • Zparts01
              • Nov 2021
              • 107
              mon2 I was able to get the new chips. Although they are the same number the last 3 characters are not the same. The one I had ends in NIG and the new one in SIG. They look the same spec on paper, but the size profile is a little wider. Hope that's no an issue. Anyway, I am guessing my programer is fried as the new chips do not work in it either. Could there be any other reason for this? I have checked the adapter configuration schema several times and it is right, but still does not see the chip, new or old.
              • mon2
                • Dec 2019
                • 14662
                Does the programmer function correctly with other 3v3 flash devices?
                • Zparts01
                  • Nov 2021
                  • 107
                  Yes, it's fine as a 3.3v without the adapter.
                  • mon2
                    • Dec 2019
                    • 14662
                    So the fault is with the adapter and/or seating into the fake ZIF sockets.
                    Confirm that the orientation of this adapter board is correct for your purchased model.
                    Review the male pins that mate with the zero force socket and be sure that each is with a clean solder joint on the bottom side of this adapter PCB.
                    My bet is on a dry solder connection.
                    Recently purchased from (low cost) RISC-V kits from a vendor on Aliexpress. Out of the 5 kits, 3 did not work. Had to resolder the onboard LCD display connector. The vendor was amazing to chat with me till midnight, their time in Shenzhen so 5 stars for the service. He agreed that he will kick their QC team to correct these faults for future builds.
                    • Zparts01
                      • Nov 2021
                      • 107
                      Ah! Great info thanks! I think you might be right! I'm at the office right now, but I'll be checking that tonight. I just assumed the solder joints would be good. It would be good if that's the only problem. I'll let you know!
                      • Zparts01
                        • Nov 2021
                        • 107
                        Sadly it was not the solder joints. I have checked each one carefully and even refreshed them, but still nothing. I will order a new CH341A if you think it must be the adapter . I bought the one I have as a kit, comes with everything. I will just do the same if you believe it's a good idea?
                        • Zparts01
                          • Nov 2021
                          • 107
                          Ok, so I received my new CH341A and indeed the old one was fried. I was able to erase one of the new chips and write the saved good backup file (the one I posted here) to the chip, then soldered it back to the board, but still no power. I went over everything I could think of once again and even went as far as to remove and re-ball the BGA chip others had questioned, just in case something was shorting out, when I removed it I could tell it was a perfect clean install, but I cleaned everything off and re-balled it again. No difference. Still no power. Without the right schematics and bad I'm kind of flying blind. I have tested the board in several areas for voltage and shorts, but can't find anything. Any more ideas?
                          • mon2
                            • Dec 2019
                            • 14662
                            The only other variable at possible play here is the QE bit.
                            By factory default, both the original and replacement do NOT have QE=1. This means standard, slow spi commands and data flow are applicable.
                            It is still possible that the original chip was programmed with QE=1 for QSPI mode communication.
                            There has to be a freeware programming software to check and allow you to toggle the QE bit of your flash.
                            If and when found, you could enable the QE bit and test again. The data sheet mentions to not enable the QE bit if some of the lines (/WP and /hold) are tied low. You can check this before attempting.
                            • Zparts01
                              • Nov 2021
                              • 107
                              Thanks mon2! I will do some research this topic and see what I can find some free software to help. I'll post when I find it!
                              • Zparts01
                                • Nov 2021
                                • 107
                                After searching for the better part of two days, I can't seem to find any software that would allow me to change the QE bit to QE=1. Any ideas what I might use to do this?
                                • Zparts01
                                  • Nov 2021
                                  • 107
                                  Anyone?
                                  • mon2
                                    • Dec 2019
                                    • 14662
                                    It blows my mind that there is no public code for this feature. It is a simple extension to the code that has already been developed. Due to the drunk driver accident into our building, very difficult to find this programmer tool but will review as time permits. As of yesterday, found some source code but do not have this IC on hand. Summary - with some quality time, it should be possible to tweak the existing public source code to support this feature. No ETA.
                                    • reformatt
                                      • Feb 2020
                                      • 1495
                                      T56 and SVOD both support it. Status Reg in the Xgecu software, or Config SPI in SVOD.
                                      Maybe take a look here for AsProgrammer:
                                      https://khandishnetwork.com/2021/01/...rror-solution/
                                      For a 25Q64FV chip I had lying around and threw in my T56, says that S9 is for Quad Enable.
                                      • Zparts01
                                        • Nov 2021
                                        • 107
                                        Thanks mon2! First of all, sorry to hear about the drunk driver accident! I hope everyone is ok! ... I was also surprised there did not seem to be a tool available to switch from QE=0 to QE=1 ... Hopefully when time permits you can tweak the source code. As this is just a fun project/learning experience, No in any big rush, unless I get tired of looking at the parts everywhere and just scrap it. Lol (I'm sure I won't do that)
                                        • Zparts01
                                          • Nov 2021
                                          • 107
                                          Thanks reformatt! I will look into what you wrote. I'll be checking that link out for sure! Maybe I will find the answers I'm looking for there!
                                          • eukal
                                            Panasonic toughbook cf-h2 Mk1 no power, 3.3v-5v present but no 3v on bios chip
                                            by eukal
                                            Hello, i have a Panasonic Toughbook Cf-H2 Mk1 that won't power on. The battery charge without problem but no response from the laptop when i press the power button.
                                            I have disassemble and unpluged the cmos battery, same no power on on battery with and whitout the adapter, and only adapter
                                            I have check the voltage i have the main power rail ( +-16v normal for toughbook it's not 19v). I have on the coil after power management chip 3.3v and 5v.
                                            I have check the 3.3v on the power button ribbon cable attach to the motherboard and the voltage go to 0v when i press the button. So...
                                            07-01-2023, 01:00 PM
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • iulik17d
                                            Intel Arc A380 videocard power limit remove - BIOS needed
                                            by iulik17d
                                            Hello everyone!
                                            The Asrock A380 low profile card (ID 8086 56A5 - 1849 6006) have an power limit of 45W. Intel removed the possibility to increase power using the software utility, anyway the card is in an proxmox machine that doesn't run windows.
                                            The same hardware is in another form by the name Asrock A380 Challenger that have the same VRMs and the power limit is at 60W. I searched online and found on another website an .bin bios file from the Challenger variant, that I flashed using an CH341a. Flashng worked well, I put the card in PC and booted. GPUz shows that new device ID is 8086...
                                            01-10-2025, 02:33 PM
                                          • hotcrossedbuns999
                                            M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
                                            by hotcrossedbuns999
                                            My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
                                            1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
                                            2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
                                            3. I could only locate two chips that look like bios chips. Could someone verify this
                                            01-03-2025, 12:32 PM
                                          • capoplays
                                            Help with BIOS update on Dell G15 5515 after chip replacement
                                            by capoplays
                                            Hey everyone,
                                            I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                                            The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                                            When I check the BIOS using the F12 menu Flash...
                                            10-24-2025, 06:53 AM
