820-00165-A Missing PP5V_S4RS3 and PP3V3_S4SW_SNS
  • Flippers McCoy
    Tinkerer
    • Mar 2018
    • 106
    Re: 820-00165-A Missing PP5V_S4RS3 and PP3V3_S4SW_SNS
    None taken! I definitely agree, a heat gun is far from ideal, and it's likely preventing me from doing as good a job as I could. Honestly I wouldn't be too broken up if I didn't get the job, I very much enjoy repairing motherboards
    • piernov
      • Jan 2016
      • 4435
      • France
      If PP3V3_S4 is there that would be great news, make sure you have PM_SLP_S4_L.
      • Flippers McCoy
        Tinkerer
        • Mar 2018
        • 106
        PM_SLP_S4_L doesn't exist, still
        On a hunch, I checked for continuity to ground on PM_SLP_S4_L, and it's shorted to ground!
        It's a 3.3V rail, right? So I should start by injecting voltage into the rail and see what gets hot
        • Flippers McCoy
          Tinkerer
          • Mar 2018
          • 106
          So I started trying to figure out where the short on PM_SLP_S4_L is, and I learned that it is only shorted to ground when the board has the adapter plugged in.
          Is it safe to inject 3V to find a short, or is that even necessary?
            • 20709
            Have a look at the power state table, page 59 on the schematic. Test everything on the PM_SLP_S4_L rail U3510 ,
            • Flippers McCoy
              Tinkerer
              • Mar 2018
              • 106
              To confirm I'm interpreting the table correctly, the 1s mean that state is off/inactive, and 0s mean that that state is on/active, right? So the rails on the top of the table are necessary in order to have all the 0s below them.
              All the components passed a visual inspection, but I don't think that really counts for much at this point. I didn't bother checking to see if the ICs were outputting what they're supposed to because they both operate on S3 or S4 rails, and we're not even getting into S4 state.
              R1461: 49 Ohms
              U3510: 48 Ohms
              U4810 (pin 1): 52 Ohms
              U4810 (pin 5): 50.5 Ohms
              R8179: 50.5 Ohms
              R8111: 49.5 Ohms
              R8116: 50 Ohms
              R8112: 51 Ohms
              R8117: 52 Ohms
                • 20709
                The 1 = enable
                • Flippers McCoy
                  Tinkerer
                  • Mar 2018
                  • 106
                  Ah, so the opposite of what I thought then, good to know
                  I think I see what you were getting at, PM_SLP_S5_L is in the exact same boat as PM_SLP_S4_L with a short to ground only when the adapter is plugged in.
                  The only component that I can see that both these rails have in common is the CPU, and I would be loathe to think the CPU is at fault here
                    • 20709
                    I could be wrong here,but the only things i can see in common are 2 resistors R1460 (100K ohms) and R1461 (100K Ohms) , and U8170 Pin 2 PM_SLP_S5_L to U8170 Pin 4 S4_PWR_EN that goes to,amongst other things Q2090 Pin 2 S4_PWR_EN to Q2090 Pin 5 PM_SLP_S4_L
                    • Flippers McCoy
                      Tinkerer
                      • Mar 2018
                      • 106
                      Both Q2090 and U8170 don't exist, they seemsto be part of a diagnostic circuit for test boards. It looks like literally the only things that are real that PM_SLP_S5_L actually goes to are U5000, R1460, R8115, and U0500. I would try removing R1460 and R8115 one by one to see if either removes the short, but I don't see how either of them being shorted would cause these symptoms specifically
                      • Flippers McCoy
                        Tinkerer
                        • Mar 2018
                        • 106
                        Okay, so I discovered that all three of these rails are shorted to ground:
                        PM_SLP_S5_L
                        PM_SLP_S4_L
                        PM_SLP_S3_L
                        Perhaps a bad SMC?
                        None of the other resistors in that area of page 13 are having problems like this
                          • 20709
                          Damn these apple schematics, i must have been zoomed in too far to see (For development only)
                            • 20709
                            It could be a bad SMC, it might just need reballing. You`ll need to reball an SMC sooner or later .
                            • Flippers McCoy
                              Tinkerer
                              • Mar 2018
                              • 106
                              If it's the SMC I'll have to set it aside for another day.
                              I did a little more research, and it looks like in order to get PM_SLP_S4_L, you need PCH_PWROK, and to have PCH_PWROK you need PM_S0_PGOOD. That comes from U1950 on page 17. I checked on it and it has power coming in on pin 8, but pins 1 and 2 are both 0V, so it's not creating PM_S0_PGOOD. I looked into where ALL_SYS_PWRGD and CPUVR_PGOOD_R come from, but I quickly got lost.
                              I used this Rossmann video to learn more about this circuit
                              It looks like the whole short to ground thing was a misdirection and may be supposed to happen? Apparently testing for continuity while power is on a board is a no-no.
                              • piernov
                                • Jan 2016
                                • 4435
                                • France
                                #35
                                You need to have the AC adapter *unplugged* to check for shorts.
                                PM_SLP_S4_L doesn't need PCH_PWROK AFAIK. The power ok signal would be RSMRST# in this case.
                                • Flippers McCoy
                                  Tinkerer
                                  • Mar 2018
                                  • 106
                                  That's what I thought, but I never saw it put explicitly like that, thank you
                                  PM_RSMRST_L is 3.29V. Is that supposed to be low in order to get PM_SLP_S4_L?
                                  I also get 3.33V on pin 2 of U8130 and 3.29V-3.3V on pin 4
                                  PS: How can I tell which power ok signal is for which rail?
                                  • piernov
                                    • Jan 2016
                                    • 4435
                                    • France
                                    #37
                                    No, RSMRST# is supposed to be high, along with RTCRST#, SRTCRST#, INTVRMEN# and PWRBTN#. That last one needs to be low for a short time after RSMRST# goes high, but you won't be able to check that without an oscilloscope.
                                    If you still don't get PM_SLP_S4_L (nothing at all, no spike) maybe the RTC clock generator or some trace around there is bad. You need to check with an oscilloscope if it looks ok. Or anything that has an ADC, 32kHz is pretty low frequency so it should be easy to measure.
                                    I don't see anything else but maybe I'm missing something. (could be the PCH but chances are low)
                                    • Flippers McCoy
                                      Tinkerer
                                      • Mar 2018
                                      • 106
                                      Gotcha, gotcha, thanks
                                      When I plug it in while reading PM_SLP_S4_L, it goes up to 1mV, then back down to .5mV where it stays, I don't think that counts as a spike?
                                      How would I test the RTC generator if I have an o-scope? I got the datasheet for U1900, but I wasn't sure which pin to test for what at. I may be able to get my hands on an o-scope briefly at my university, but I wouldn't have a ton of time to hang out, I'd have to know what to look for before sitting down with it
                                      • techrepairheide
                                        MacBook Pro (A1502 / 820-3476-A) - No orange/green light and no power
                                        by techrepairheide
                                        Hello again,
                                        got an MacBook Pro from 2015, model A1502 and motherboard version 820-3476-A.
                                        Device died over night on charger.
                                        Currently I did the follow things:
                                        1. Checked visuell the board, test with another MagSafe-Charger and with another DC-IN-board too
                                        2. Measured 16,5V on ​PP18V5_DCIN_FUSE but 0V on ADAPTER_SENSE and 0V on PP_3V42_G3H and 0V on PPBUS_G3H but 16,5V goes to U7090
                                        3. Because of corrosion and bad resistor values I changed these components: U7090 / C7094 / C7095 / R7095 / R7096 / L7095 / C7099 -> But further...
                                        01-26-2025, 05:37 AM
                                      • mon2
                                        A1466 Macbook Air (Liquid damage repair)
                                        by mon2
                                        Hi. Recently serviced a damaged A1466 Macbook Air. Thought to post the issues and resolution for each.
                                        Macbook AIR Model A1466 Diagnostic 09-01-2021
                                        Issue: Liquid damaged (beer spill) Macbook AIR will not power up.
                                        Problems & Resolutions
                                        1) Attached Apple magsafe power adapter. No green / no orange light. This confirms the absence of the PP3V42_G3H voltage rail. The PP3V42_G3H rail is the primary voltage rail necessary to communicate with the magsafe power adapter to report the green or orange light status to the end user....
                                        09-01-2021, 09:31 AM
                                      • speggio91
                                        820-00165 no greenlight in S0 state
                                        by speggio91
                                        I've started to practise more on macbooks air board, I've got a bunch of defective ones, to see if I can gain some more knowledge.
                                        I've been focused on a water damaged board of an 2017 Air.
                                        Someone else already worked on it, the SMC has been reflowed plus some minor reflows around the board.
                                        I've reached a dead end but I improved the state of the board.
                                        Initially it was no power, no green light, no fan spin, stuck at S5 state.
                                        After replacing some components (U7090, Q5500, Q7430, C7432, Q7630, U1950, R6115, R6116,...
                                        11-19-2023, 09:56 AM
                                      • bridges_4u
                                        A1466 820-000165-A with low PP3v42
                                        by bridges_4u
                                        I have got an 820-000165-A motherboard which has got a strange problem. I have 14.32 V at R7005. But when i check pin2 of D7005, it says 0.9V. The diode is OK. Tried changing U7090 too. Any clues?
                                        04-02-2023, 10:47 AM
                                      • m3g4tr0n
                                        820-4924-A - No Green Light
                                        by m3g4tr0n
                                        Have a 820-4924-A - with no Green light on the charger.
                                        R7020 looks discolored and measures 31.9ohms insstead of 47ohm.
                                        attached a picture with voltages between dc jack and u7090.
                                        also getting a short to ground on PP3V42_G3H (L7095, C7099, C7010, C7008, ...)
                                        took off u7090 and L7095, C7099 and short still there. didn't take anything else off.
                                        thanks...
                                        02-09-2021, 06:00 AM
