Samsung 52" LCD Intermittent Vertical Bar
  • tibimakai
    • Jan 2012
    • 3680
    Re: Samsung 52" LCD Intermittent Vertical Bar
    In my opinion it's the panel. See if your upper tabs are darker on that side where the lines appear and if they are, then it's most likely the driver IC is bad in that(those) tabs.
    A guy on craigslist contacted me, and he was claiming that he can fix these tab issues, but he didn't mention how. It looks like it's possible, but we don't know how.
    Once I managed to put it together in a way that it worked perfectly and I let it run for a couple of hours, but then the lines came back.
    The only thing I would do, is to try another T-con board and if it's not working, then I would sell it to somebody else(maybe he is able to fix it). See if you can return the board in case that it's not working out. I was lucky with an Ebayer, don't remember his name but it was from Santa Clarita CA.
    • tripslipfall
      • Sep 2011
      • 23
      I really don't wanna tear it apart down to the tabs, but flexing, tapping, hitting, pushing, nothing you can do changes the lines at all. I wanna see if I can find a T-Con locally but I'm running out of time. I need the TV out of here by the 30th. They change ramdomly. Sometimes it takes hours, but it's getting worse.
      • danbass
        • Aug 2012
        • 2
        Hello! Sorry to jump in on someone else's thread, but I believe it might be valuable information. I had the same issue as Trips, around a 3" distorted or black bar on the far right of the left half of the screen which came in and out.
        After replacing the suspected bad caps, which I've done before on another Samsung, the screen stayed exactly the same. After searching bad caps I ran into this YouTube video:
        http://www.youtube.com/watch?v=8P_i-...e_gdata_player
        After reseating the two ribbon cables coming out of the tcon, the problem went away completely and the image was perfect.
        However, after putting the tv back together, while there is no vertical line problem, the image is now washed up and so bright that most menu text is unreadable. I've since reseated all of the cables and the display stays this way.
        Any suggestions? Tv is a Samsung LN52A550P3FXZA. Haven't found any one else on this forum with a brightness contrast issue with a Samsung.
        Originally posted by tripslipfall
        Okay so here's a picture of the horizontal lines, you can see the multicolored bar, and here's a short video of what the bar does when it's acting up and showing that sometimes turning it off makes it work perfectly. I apologize for the bad quality and no audio, it's all I have at the moment but it gets the point across.
        http://www.youtube.com/watch?v=CWFKGI_Cqzk
        • 102mm
          • Dec 2013
          • 181
          • us
          Is this thread still going on. I just fixed TWO OF THESE TV'S with three exact same problem. It's the ribbons going into the LCD panel itself.. More specifically, it's the boards that connect to the ribbon cables. In one of them I simply put a ribbon cable on top of the original cable and it fixed it.. Dunno how. The second one I reseated the two boards.. Not sure you exists would call it a fix but I now have 2 52 inch TVs for $160..
          Craigslist Picks & Fixes
          2 ea - Samsung 52"
          Samsung 60"
            09-07-2024, 05:50 AM
          • C152Heavy
            Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
            by C152Heavy
            Summary for TL-DR readers:
            • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
            • Have obtained Samsung schematic & service documents - Can upload if helpful.
            • Have read ALL applicable threads
            • C1818 and CP820 replaced as low hanging fruit
            • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
            • VCC pin (18) of PFC...
            01-11-2023, 02:53 PM
          • kotel studios
            Samsung LC32HG70QQUXEN - vertical and horizontal stripes across the screen
            by kotel studios
            Just now my Samsung LC32HG70QQUXEN monitor gave up on me. On cold boots I get many vertical stripes going across the screen (see the attached picture). After it runs for 1-2 minutes those go away but there are horizontal stripes going across the whole screen no matter of the input and PCs I use. (couldn't take an picture of it since the image size goes to 20MB and the camera doesn't pick them up)
            In a video about a 27" monitor with an similar issue the guy removes one resistor and supposedly the entire monitor goes back to life? For sure this fix is only temporary....
            08-06-2025, 02:07 AM
          • JesusJones
            Samsung Plasma Intermittent Vertical Bars (repeatable) PN50B430
            by JesusJones
            Trash picked this plasma for parts and found it had some bad solder joints. It powered on after reworking most of the boards and seems like it may even work.
            The symptoms is, when showing a picture of bright (mostly white) intensity (within the affected area only) a vertical strip 2 3/4" wide will begin to fuzz out (just to the right of samsung logo, 16 3/8" from screen edge), and soon turns black (from top to bottom). Changing to a darker scene immediatley ater will cause the black stripe to fade back in (it fuzzes and clears up again) and it starts working just fine....
            04-13-2021, 01:45 PM
            09-06-2024, 11:40 PM
