Samsung Plasma TV - Worth Repairing?
  • Mr Bill
    • Nov 2011
    • 648
    Re: Samsung Plasma TV - Worth Repairing?
    According to shop jimmy.com one of the x-mains are interchangable so i some might but to confirm you'll have to verify the board numbers on both. Is the philips you want to use as a parts tv have a broken panel?
    This was pulled from a philps pdp manual concerning the led light on the y main:
    If the LED is ON then you have a problem with the Panel,
    Y- Buffers or Y-Main Board. Starting at the panel connections
    unplug them and then Y-Buffers one at a time (while unplugging
    & plugging the AC cord). Each time confirm if the LED stays ON
    after unplugging the connectors from the Panel to the Y-Buffers.
    • zukdj
      • Jun 2012
      • 104
      The Samsung has an LED light on on the Y-SUS, not the Philips.
      • Mr Bill
        • Nov 2011
        • 648
        So the y-sus is different between the samsung and your philips? My 50PFP5332D/37 has a green led on the y-sus.
        • electronicsurplus
          • Jun 2012
          • 210
          Your problem is in the Power Supply. If the set is clicking
          have repaired these 100 times already. It is a common problem
          you will need to get:
          HPT4254 Deluxe PSU Repair Kit
          Contents:
          1 8A 250V Time Delay/Slow Blow 5mm X 20mm fuse
          2 FQPF9N50CF MOSFETs
          2 FDA18N50 MOSFETs(substitutes for 2 FQA13N50CF)
          4 20 ohm 0.25W SMD/MELF resistors
          2 10k ohm 0.25W SMD/MELF resistors
          2 1SS184T5LFT SMD dual common cathode ultra fast recovery diodes
          2 2200uF 25V capacitors(replaces CX813 and CX814)
          1 1gram tube of heat sink compound
          to repair that television.
          You can just change the caps but, it will ONLY last a few days. The diodes go bad and, the resistors lose value, which in turn will kill the new caps if you install them only
          There are kits available specifically for this television. I am not sure if it is available on this site, but, I think it might be
          Jon
          Electronic Surplus
          This Forum absolutely the best and, the most helpful forum I have ever found anywhere. thanks to all the fantastic members here
          Help keep these from the landfills
          • electronicsurplus
            • Jun 2012
            • 210
            also, In fact, I am working on 2 of the same exact televisions as we speak.
            I have the entire Power Supply available, also, if needed
            Jon
            Electronic Surplus Recyclers
            • electronicsurplus
              • Jun 2012
              • 210
              I have bought this kit @ http://www.preher-tech.com/electronicsrepairkits and, they all worked very well
              Even has a manual and instruxctions as to where they are and which to change
              • zukdj
                • Jun 2012
                • 104
                Jon, how much for the rebuilt power supply? Is it cheaper if I mail you back the old one to rebuild and keep for yourself as a spare to sell or to rebuild for me? My TV is an HPT5064 with no video but excellent sound, it was clicking on and off early on but that stopped and there is still sound but no video. The weird thing is if I use the RCA inputs for a DVD to produce sound and pull the (yellow) video-in cable from the TV the sound stops, I thought red and white were audio and yellow was video only - WTF? If you are sure its the power supply I'll purchase it if reasonable, the TV is only 3+ years old, the logic board is already new and all the heat sinks on the power supply, X & Y heat up evenly, LED light is on on the Y-SUS. Is there anything specifically I can look for to be sure?
                • zukdj
                  • Jun 2012
                  • 104
                  Actually just got off thye phone with Preher-Tech, if I send the board to them they can fix it for $65. Just need to know what you want for yours.
                  • electronicsurplus
                    • Jun 2012
                    • 210
                    $29.00 + shipping
                    • electronicsurplus
                      • Jun 2012
                      • 210
                      That is exchange price
                      • infringer
                        Badcaps Member
                        • Sep 2009
                        • 244
                        • United Frickin States
                        #31
                        Oddly I have had this happen to me with a CHE MEI panel and it was none of the above I didn't find the problem till I went further into the panel and seen that the backlights were arcing off on the frame the real bummer is by the time I had found and had lights ordered the screen got busted cause something was set on top of it so I had good backlights and a busted screen.
                        But either way it was very interesting I would not turn it on anymore you may risk blowing something more due to the arcing if this is the case.
                        Anyhow take care and good luck with this one.
                        Please note: I am not responsible for any harm caused to you anything discussed is just discussion. Before you try anything discussed be sure that you have the appropriate knowledge and safety gear for the job. Like with anything education and safety are first! Do not try anything @ home without it.
                        • electronicsurplus
                          • Jun 2012
                          • 210
                          OK, in that case. test the buffers to see whether they are shorted or not
                          In some cases the power supply will also click if it is under heavy load such as by Burned Y-Buffers or Y-Sustain
                          This link shows you how to test the buffers
                          http://blog.coppelltvrepair.com/2010...er-boards.html
                          You can also try removing either the top or bottom and turn the set on, IF one of the buffers are bad you will have 1/2 screen either top or bottom depending on which , or both, are bad
                          Jon
                          • electronicsurplus
                            • Jun 2012
                            • 210
                            I must admit, Preher does do a fantastic job and super fast
                            • mr.sky
                              • Sep 2011
                              • 54
                              #34
                              Yes, I highly recommend John Preher, very honest and straight shooter.
                              • zukdj
                                • Jun 2012
                                • 104
                                So are you saying the tiny LED on the y-sus board shouldn't be lit when there is power to it? If it is that indicates a problem?
                                Mr.Bill I have a Philips 50PFP5332D with a bad power supply being rebuild by Preher-Tech and a Samsung HPT5064. I am focusing on the Samsung repair now but I don't want to spend a lot of money on it at this point since I've already invested almost $100 into it, I get not a thing on the display but perfect sound. In addition I noticed using my DVD player to get sound that I need the red, white and (yellow video????) RCA jack plugged in to get sound, if I pull out the yellow RCA video jack the sound stops. I plugged just the tip in being careful no to make a full connection with the outside of the yellow RCA jack ring and the sound comes back....weird. It's almost as though it has a bad ground. Is it possible the main board is FUBAR, I've already replaced the main logic board? I just don'T know if I should waste anymore time or $$$ on this TV or just take it apart and use it for parts? Suggestions?
                                • capkid
                                  • Oct 2010
                                  • 1339
                                  Ugh, I was hoping this would be an easy one. I guess I'll order the kit. And yes, John Preher is a good dude - I've learned a lot from him via Internet correspondence; he knows his stuff. I actually didn't realize until awhile after initially corresponding with him that he lives about 30 miles from me - LOL.
                                  LG Plasma Mal-Discharge Correction Service
                                  • capkid
                                    • Oct 2010
                                    • 1339
                                    • capkid
                                      • Oct 2010
                                      • 1339
                                      I found this kit on eBay: http://www.ebay.com/itm/160846772558...558%26_rdc%3D1
                                      It appears to have the same components as Preher-Tech's kit, minus the caps. Has anyone purchased from this seller?
                                      • parks992
                                        • Apr 2013
                                        • 1
                                        $29.00 + shipping
                                        Can you still do this repair exchange price? I have the HPT4254 that has the shut off clicking issue. I don't see anything visually on the power supply board that looks bad. Was hoping to see some blown caps that I would be able to replace, but no such luck. It stops clicking when I unplug the main board(one with inputs). I'm hoping it is just the power supply board.
                                        Rich
                                        • jmh139
                                          • May 2013
                                          • 1
                                          $29.00 + shipping
                                          Tried to send PM, but could not as I am new. Are you still offering to these boards as a swap? Thanks Jay
                                            09-07-2024, 05:50 AM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
                                            Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook Specification for Upgrade or Repair
                                            This specification for the Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-X01DE boardview and NP950XCJ-X01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 06:20 PM
