How to buy a main board for LG42lf66? which code shall i look for..
  • tn245
    • Oct 2013
    • 530
    Re: How to buy a main board for LG42lf66? which code shall i look for..
    Probably tomorrow or Friday depending on when I have time. My TVs symptoms are slightly different from yours so can't guarantee that what fixes mine will fix yours but it seems those caps are the known issue. It's prob not in his interest to tell you what the fix is before you pay him I guess.
    If you do go for it I'd be very happy to know what changes he makes. I'd guess he'd probably use the surface mount caps rather than the through-hole ones, so the board might not look any different to the eye.
    • tn245
      • Oct 2013
      • 530
      Hey Zelig, any updates? I sold the one I fixed to a guy who immediately cracked the screen while trying to mount it on his wall. So if you need a working main board I've got one, with troublesome caps already replaced.
      • nikonite
        • Oct 2014
        • 10
        • United Kingdom
        Sorry to drag up an old post but I too am looking for this board if anyone still has one for sale? If not I have the rest of the TV for spares if anyone needs anything before I tip it?
        • Arudge
          • Jan 2015
          I have an LG 37LF65 which developed a terrible flicker.
          It would be fine for the first 5 minuets and then start to flicker, the picture was so bad it was completely in unwatchable, but after 20 mins it would settle down. This 20 mins soon became an hour which was clearly no good.
          I found one visible bad cap on the power board, as is best practice I replaced the lot, about 22 of them, this cut the flicker time back down to twenty mins but clearly wasn't the problem.
          I moved on and took tn245's advice and replaced the 6 caps marked c901, c954, c533, c970, c975 and c 915 on the main board.
          Voila, no more flicker.
          Thank you guys,
          • Dani_2024
            by Dani_2024
            10-28-2024, 05:06 PM
          • ygorsan
            by ygorsan
            🧩 Problem Summary:
            • I
            07-28-2025, 08:34 AM
          • jb_Bak
            by jb_Bak
            CN6401
            Pin 01 NC
            Pin 02 NC
            Pin 03 "BL_ON": 0V
            Pin 04 "N/C"
            Pin 05 "STBY 3.3V": 3.5V
            Pin 06 "GND": N/C
            Pin 07 "AC_OFF"...
            09-27-2021, 04:52 PM
          • JDC
            (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
            by JDC
            ONN 100012588
            Issue: No Power, Then Rebooting After Main Board Change
            Short answer: replace main board and power board
            Technical answer: replace main board and Q306 & Q307 on power board.
            Long answer:
            TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
            07-15-2022, 07:39 AM
          • cheeky2
            by cheeky2
            05-25-2024, 03:27 AM
