Lumenia street light; LED power supply driver
    Hello, I've got driver module of a LED street light lamp that had an ant colony inside and probably due to some ant organic fluid driver module shorted.
    Fuse is blown, one of the znr varistor is shorted and there is a burnt resistor from which I cant read the value.
    Does anyone by any chance has a schematics for this driver?
    Thank you
    https://lumenia.com/products/street-...as/e-lum-.html
    Re: Lumenia street light; LED power supply driver
    whats the gray metal with philips written on it?
    the vertical pcb is a psu, it looks like the output voltage is marked on it maybe.
    why does it have a computer and a radio??????
      I think its the actual power supply for led and a pcb supplies voltage for RF controller and drives the actual power supply for led.
        I'd first soak the PCB in IPA (if the relay is sealed) to clean off all the fly shit. Use a toothbrush.
        The exploded part does not look like a resistor.
        The RF controller is obviously to communicate with spy balloons and offer remote control.
          seriously? i thought it was da 6G to directly beam communications to the creator in china.
          you know, if it was made by pfizer they would remotely increase the led current after the warranty expires to kill the leds
            It looks way overboard. A 68-pin MCU to control one string 24-LED streetlight? Plus RF transceiver and antenna.
            It must program people by blinking at the DNA frequency... the Mind Control Option now in your Lumenia street light.
            cog-rf-1x-spa1 might use STMicroelectronics SPIRIT1 RF Transceiver.
              The exploded part is marked R17 on pcb. You're right I'll first give it a good cleanup.
                Talking about ants, reminds me that my sister is dreading a bunch of tiny ants coming into our house!
                In 2022, I already had to get rid of many ants in the other computer room, the same one where I had a motherboard failure already and it getting replaced with an X570 motherboard.
                ASRock B550 PG Velocita
                Ryzen 9 "Vermeer" 5900X
                Arc A770 16 GB
                eVGA Supernova G3 750W
                Alienware AW3423DWF OLED
                  Have the engineers gone mad about doing this crap why do they think that they have to control everything like this
                  I have seen some switching power supply that have a supervisor ic chip like in some industrial machinery before really what I want to know is WHY and for WHAT reasons could they have for doing this
                  What is interesting about this one was if you removed the ic chip then the switching power supply came back to life but the machine would not power on really
                  In fact I had to replace this switching power supply twice because of different issues with the switching power supply one time it was the supervisor ic chip failure and the second time it was the switching transformer failure
                  so I just switched parts around and got it working again
                    Back to getting ants! I'm seeing them mostly near the main bedroom doorway.
                    Arc A770 16 GB
                      get some powdered aspartame or neotame and throw it on the floor where they walk
                        Boil a bunch of water, dump muriatic acid down the ants nest followed with hot water. Kills every stubborn ants nest I came across. A mix of muriatic acid and water is a very good ant killer, but for outdoor use only. It’s got to be very well ventilated.
