LENOVO Ideapad 3-14IIL05 no display even after bios flash
  • albertooo
    • Jul 2016
    • 26
    • china
    I have LENOVO Ideapad 3-14IIL05 model:81WD it doesnt display,,but power light on,i have tried flashing a clean bios but still the same problem...please help me give me any idea.
  • hoaca388
    Badcaps
    • Jan 2022
    • 12406
    Re: LENOVO Ideapad 3-14IIL05 no display even after bios flash
    How much time do you give it after pressing the power button?
    • albertooo
      • Jul 2016
      • 26
      • china
      i have waited for 30 minutes but no display coming.
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        You have given us all the measurements.So its our fault we couldnt help you.
        • johnwarlock
          • Dec 2020
          • 5
          • Philippines
          i have same problem... but in my case all voltage is present and my laptop read 0.498 amperes but no display no capslock i already flash the bios but same issue no display no capslock 0.498 ampers
          • Udemzy
            • May 2017
            • 166
            • Guatemala
            Check DC/DC section then check if voltage is available on all coils.
            • mkdj
              Lenovo IdeaPad 3 - Hard Disk not recognized in BIOS
              by mkdj
              Dear all,
              I have recently fixed a Lenovo IdeaPad 3 15 ALC6 that was not booting due to a BIOS issue. After flashing the BIOS, the laptop boots up, but hard disk is not recognized in BIOS. Is says "Hard Disk : Not Installed". I have tried with 2 different drives (one that I know is working on another laptop) but I get the same result. I do not know if disks were recognized before I got the laptop and fix it, but I don't see any reason why not. I can boot on USB though.
              Here the steps I have taken to fix the laptop:
              - downloaded latest BIOS from Lenovo Website...
              10-18-2025, 03:43 AM
            • abhorsen
              Help Disabling Flash Protection Range Registers on Lenovo P360 Tiny BIOS
              by abhorsen
              Hey guys,
              Hope you all are doing well. I come here from Win-Raid because I am having issues disabling Flash Protection Range Registers so I can flash my BIOS from within Windows using Intel's IFW tool/using flashrom within Linux, however I cannot due to the above mentioned error.
              Here is my thread on Win-Raid detailing the whole process I went through: https://winraid.level1techs.com/t/re...h-gen/95478/27
              Essentially I managed to boot into Windows while shorting PINs 1+5 of my audio chip to disable the HAP bit...
              07-06-2023, 10:22 AM
            • Vesko356
              by Vesko356
              08-11-2023, 03:27 AM
            • HotSaladMan
              Lenovo ThinkBook 14S Yoga ITL Bad Flash + Need Bios
              by HotSaladMan
              *##*#*#*#*#*#Cringe Warning Used Clips for Tl866ii Plus Backups#*#*#*#*#*#
              Model : Lenovo ThinkBook 14S Yoga ITL
              S/N : MP28JT19
              MFG Date : 2022/02/09
              Factory ID PRC4
              MO : MPNXB26080FX
              MTM : 20WE001US
              MODULE FCC ID : PD9AX201NG
              IC : 1000M-AX201NG
              BOARD INFO
              FLV34 LA-KO51P
              REV : 1B 2020-08-24
              Bit of Info
              Using Tl866ii Plus, it would scan the chip but wouldn't not detect the
              chip id, so i would always uncheck the id check, so it would bypass the error
              i did in fact make...
              11-07-2024, 07:46 AM
            • Nicola Bianchi
              Lenovo x1 nano gen 1 -- bricked -- where to flash the bios/fw
              by Nicola Bianchi
              Hello!
              A few days ago I bricked my Lenovo x1 nano gen 1 while updating the bios/fw from linux.
              No the machine power up, but it stuck in a recovery state and I can not do much.
              Lenovo X1 Nano Gen 1
              Type: 20UN - X021US
              S/N: R9 - 10W2D9
              I would like to flash a new BIOS/FW on the chip using a CH341a programmer but ... I actually don't know which "chip" on the motherboard to target 🤦‍♂️
              So here I am to ask for help.
              I opened the laptop and I found a chip that may be the target, on it I've:
              Winbond 25R256...
              01-11-2025, 09:50 AM
