This Viewsonic VA2026W needed one capacitor replaced
  • lkvee
    • Feb 2009
    • 198
    Got it from Freecycle with power and brightness issues when turned on. My Google-fu didn't turn up a specific solution, so I'll post one here to document what I've done.
    I replaced one bulging Samxon capacitor at 1000uF. If it wasn't specified for 10V, then it was specified for 16V.
    I hope this fix will last, but I'm ready to replace more capacitors, too.
  • ipman
    • Jul 2011
    • 159
    Re: This Viewsonic VA2026W needed one capacitor replaced
    Caps nearby heatsinks have a hard life. Anyway, harder than those in cool well-ventilated spaces.
    If you want to keep the device for a long time, it may worth recapping some other caps like the biggest one.
    • jetadm123
      • 2169
      With the exception of the large 450V cap, replace ALL the other small caps with low-esr caps such as Panasonic FR, FM or FC series caps.
      • ipman
        • Jul 2011
        • 159
        Ops, sorry, not the biggest one filtering HV.
        • MORETTIGIAN
          Capacitor detached from PCB – RTX 2070 Super Founders Edition
          by MORETTIGIAN
          Title:
          Description:
          During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
          I did not notice it detaching, so I am unsure of its original location on the PCB.
          Procedure performed:
          - Removed backplate
          - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
          - Reapplied thermal compound
          - Reassembled card
          Observed behavior after reassembly:
          - GPU powers on and operates normally under...
          09-18-2025, 12:14 PM
        • im_trying
          Dell Latitude 5310 2 in 1 Laptop does not power on, shorted capacitor replaced but not solved
          by im_trying
          Laptop does not power on but has a fix white light on power button, when connected to power.
          I found, while trying to diagnose, a hot spot in the motherboard and found it to be a shorted capacitor (see photo below) on the 2.5v (2D5V_S3 on schematics). After replacing it with one from a donor board, still, the board does not turn on...
          The usb-c meter reads upon connection 20.1v and 0.00a, with some occasional flashes to 0.03amps. After 10/15 seconds circa, it goes to 5.2v and draws an almost constant 0.07amps. (same behaviour as before)
          To my fingers, nothing seems...
          05-08-2025, 12:01 PM
        • veedo
          Asus FA507R no power, capacitor needed
          by veedo
          Hello
          I've got an Asus laptop which received with no power, so I found that one capacitor been damaged. I don't have schematics for that board which is DANJMMB11A0 REV:A
          Without that caps laptop is turning on fine so problem more likely is sorted but I would like to put back the correct one as it should be.
          If any way could help with sorting out specification somehow, I just know that my meter shows 11,2uF but is it 50V or 10V ?? or any others.
          See attached photo off the capacitor, maybe someone have same motherboard and can check it for me please.
          03-24-2024, 01:16 PM
        • Prolog
          RTX 3080 FE Identifying capacitor
          by Prolog
          Hi people, I hope this is the correct spot to post this, I'm new to the forum.
          I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
          I hope these photos make it clear which component I am referring to:
          (yes, the soldering is a bit botched from removing the blown one, I know)
          I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
          12-01-2024, 08:27 PM
        • chth96
          How can I test non-polarized capacitor?
          by chth96
          I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
          I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
          And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
          I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...
          06-02-2024, 07:31 PM
