Dell Ultrasharp 30" LCD Monitor ghosting...
  • slawson2000
    • Apr 2013
    • 67
    Looking at maybe purchasing a Dell 30 monitor, but apparently after a move it started ghosting. Is this an easily repairable problem? I am still pretty new at this.
    Re: Dell Ultrasharp 30" LCD Monitor ghosting...
    This will be a tab bond issue.
    This is repairable, but difficult; it depends on your level of skill.
    See this video: different problem, but same root cause (bad tab bond)
    http://www.youtube.com/watch?v=purk_SyiT44
    I wouldn't pay much, maximum £15 (around $25) because of the risk of damaging the panel.
    • slawson2000
      • Apr 2013
      • 67
      Thanks for the response. Could you elaborate what is involved with the fix?
      • leapius
        • Aug 2012
        • 60
        • uk
        As tom says, it does seem to me like a tape carrier bonding issue. Try getting some freeze spray and spray along each edge carefully whilst the screen is on to see if any changes occur at all. These ribbon tapes are stuck onto the panel using Anisotropic Conductive Film:
        http://flipchips.com/tutorial/assemb...-introduction/
        This video on the subject may be of interest to you:
        http://www.youtube.com/watch?v=Qj51BkS9d-0
        Messing about with the tape carriers is VERY risky thing to do and can render your panel completely worthless so I might buy a replacement TCON board from buychina.com to rule that out (but in all honesty it's probably not worth it - even for such an expensive display). Either way this problem is either the TCON or the connection from the TCON to the panel itself. There could be an outside chance that the power to the TCON board is at fault but this can be ruled out with a multimeter.
        • slawson2000
          • Apr 2013
          • 67
          I will steer away from this one. Thanks.
          • keepread
            Dell monitor PSU vs Dell laptop PSU
            by keepread
            Hi there!
            Someone gave me their old monitor, it's Dell S2715ht.
            The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
            Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
            Yesterday, 04:45 PM
          • Bowline
            by Bowline
            06-11-2025, 10:13 AM
          • DanPoka
            Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
            by DanPoka
            I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
            Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
            This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
            02-15-2025, 05:05 AM
            by momaka
            03-15-2023, 10:17 PM
          • nheather
            Have I Inadvertently Fixed My Dell Ultrasharp U2312 Monitor
            by nheather
            For the last few weeks I have been trying on and off to fix my Dell Ultrasharp U2312.
            I'd read that the 1084-33 voltage regulator on the logic board often needs replacing but they are pretty difficult to find in the UK, plus I don't have the hot air tools needed to replace it properly so I decided to check it instead.
            It was getting a 5.16V input and a 3.41V output so that seemed fine so I started looking at the capacitors that I could easily and cheaply replace.
            The symptoms were that the monitor would be perfect for a few minutes and then the flickering...
            03-19-2022, 05:59 AM
