LCD & LED TV Panel Removal with Suction Cups
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    A video from Shopjimmy
    https://youtu.be/BIj26QtOFRM
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    Re: LCD & LED TV Panel Removal with Suction Cups
    A few people on the forum have recomended the suction cups they do seem a good idea too be honest on the larger lcd panels.
    • SurrealMustard
      • Jan 2015
      • 487
      • The United States of America
      not a bad idea
      That probably would've made things easier the last couple of times that I had to remove an LCD panel. As long as the suction cups can't damage the panel and don't cost too much, I'd consider picking some up for next time.
      • vinceroger69
        • Mar 2012
        • 6714
        • uk
        i was thinking something like this
        http://www.ebay.co.uk/itm/2720573431...%3AMEBIDX%3AIT
        • diif
          • Feb 2014
          • 6978
          • England
          I've got a pair of those. Used to remove the glass front off an iMac, I'd never thought to use for removing an LCD screen.
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            I know that this has been discussed on the Forum and used by some but I thought that the video, seeing it done, would be informative.
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              Re: not a bad idea
              They are cheap and recently a forum member gave full details of the ones he used.
              • vinceroger69
                • Mar 2012
                • 6714
                • uk
                its a very informative video and and having the link makes it easier for us to copy into threads etc. i also find shop jimmy videos easy to understand too so ideal for hobbiest repairers etc.
                • Diah
                  • Feb 2013
                  • 6437
                  Risk with Suction Cups
                  well this method had high risk if the Panel 2 years old or more, the way to hold it up with this Suction Cups Vacuum could release the under LCD layer and got air in.. , and i saw allot even at new TV when they got transport damage..
                  • zomi
                    • Nov 2011
                    • 509
                    http://www.ebay.co.uk/itm/4-suction-...-/182246701807
                    that looks cool
                    • howardc64
                      LG 49UJ6500 LCD panel lighter band that goes away
                      by howardc64
                      49UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
                      Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on...
                      02-19-2023, 12:13 AM
                    • triplefour
                      SAMSUNG UN50TU8000F rebooting, backlight ok. No 12v to panel boards.
                      by triplefour
                      TV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
                      tcon is built into mainboard.
                      Only one cable goes to panel boards.
                      there is a cable from one panel board to the other that links them.
                      cost cutting measure that results in us having harder time to diagnose.
                      removing the link to the second panel board allows TV to stay on with stable backlight but no image.
                      used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board....
                      07-28-2022, 07:59 PM
                    • Storyteller12
                      QN55Q60R Service Menu Panel Help
                      by Storyteller12
                      I had a the above tv qn55q60r that had a bad panel but everything else good. I had another panel here from un55nu6900 with bad leds and melted diffusers.
                      I put the nu6900 panel in and powered it up and it does work but there are lines vertical lines.
                      I was trying to change the panel type in the service menu but don’t see my exact panel. Anyway to fix this or someone have similar experience.
                      the clear picture is the panel type from the service menus on the nu6900. The other 1 is the panel type that was set for the q60r with the bad panel....
                      01-13-2024, 01:57 PM
                    • maneatingmonkey
                      Missing LCD Panel Voltages VGH, VGL, VCOM (TCL 55P6US Sound & Backlight but NO Picture)
                      by maneatingmonkey
                      I have a TCL 55P6US with sound and backlight but no picture. This model does not have a T-CON board, and the right (rear perspective) panel board is fed from the left panel board. I have not been able to induce any change by disconnecting the secondary panel board or the tape cut-off method on the primary board.
                      There are a bunch of voltages missing on the panel boards. I can't find any shorted caps of the panel boards, and all of the missing voltage rails read in the kiloohms, which leads me to suspect the issue may lie on the circuit board, rather than a short in the panel.
                      03-27-2024, 07:17 AM
                    • howardc64
                      by howardc64
                      Problem
                      08-04-2024, 10:36 PM
