Anyone have schematic/boardview MS-6178?
  • dicky96
    Sun Seeker
    • Mar 2017
    • 1825
    • Spain
    Hi guys
    Does anyone have shematics for this old Pentium III motherboard MS-6178?
    They are available on a paysite but I was wondering first in anyone could share them here. Otherwise I have to pay a few euros.
    The motherboard was dead, there was 5V across the ATX Power switch pins but the PSU would not start.
    Also there is something drawing more power from the CMOS battery than I normally expect. I am reading off the scale on uA (so it's above 200uA) on my meter. Normally I get about 2uA - 10uA tops for a motherboard, unless these old boards did draw more power from the battery.
    I decided to replace the SIO W83627F-AW so I ordered a few from aliexpress
    Now I changed that the motherboard powers up when pressing the ATX power switch, the CPU fan runs and the CPU gets hot but my Post analyzer reads 0000 in any of the PCI slots. And I still have that over 200uA drawn from the CMOS battery
    I will check if I have a corrupted BIOS or possibly the BIOS revision does not support my CPU but I think I still have some hardware problem. Does anyone have the schematic or boardview so I can figure out what else is connected to cmos battery +ve
    Follow me on YouTube
    Learn Electronics Repair
  • dicky96
    Sun Seeker
    • Mar 2017
    • 1825
    • Spain
    Re: Anyone have schematic/boardview MS-6178?
    I checked on my other meter and the drain from the cmos battery was 40mA. Way too much. I checked the RTC crystal and found it is not oscillating (nor is there any bias voltage to the crystal) so I removed the south bridge thinking that was probably the problem.
    That came off OK, no damage to the PCB but when I checked the current from the CMOS battery it is not 27mA, still way too much. Having said thet it dropped by 13mA so the south bridge seems to be part of the problem, which is a step in the right direction!
    I can get a south bridge for 5 euros inc post, but that isn't going to fix it yet. What else should I try? A schematic would be really helpful
    • piernov
      • Jan 2016
      • 4437
      • France
      Leaky dual diode between coin cell battery/3VSB power rail and RTC power rail? Use continuity mode to find it with no schematics.
      Or short to ground on the RTC power rail due to another component.
      • dicky96
        Sun Seeker
        • Mar 2017
        • 1825
        • Spain
        Hi piernov. Thanks for the advice
        Something to do with a diode could be the problem as when I test on diode mode with meter +ve to battery +'ve terminal (no battery fitted of course) and meter -ve to ground I read 0.6xxV, or basically a forward biased diode junction.
        I am sure that should not happen .
        Rich
        • dicky96
          Sun Seeker
          • Mar 2017
          • 1825
          • Spain
          Just to clarify, did you mean I will have something like this circuit and the two diodes could be discrete or a three pin dual diode component probably looking like a SOT-23?
          I have direct connection 0 ohms from cmos battery + to the SIO, I checked that much.
          The RTC is in the southbridge.
          • piernov
            • Jan 2016
            • 4437
            • France
            Yes that's usually how it looks like, so that RTC power rail is fed from the power supply (5VSB converted to 3VSB) when plugged in to the mains, and backed up by the coin cell battery when disconnected from the mains. I've already seen cases where the dual diode becomes leaky between coin cell battery and 3VSB, effectively discharging the coin cell battery into 3VSB.
            Or the usual case of southbridge going short on RTC power rail…
            The coin cell battery itself can be connected directly to one of the SIO pin to monitor its voltage. But it's not supposed to actually supply power to it, as power should be taken from 3VSB directly, SIO shouldn't need a battery backup.
            • dicky96
              Sun Seeker
              • Mar 2017
              • 1825
              • Spain
              Cheers, that makes sense.
              If it was the case that the diode was leaky, would you expect the battery to stop discharging into 3VSB if the ATX PSU was connected but still in standby?
              As I have removed south bridge it can not be discharging into that, though it did reduce the current from the battery from 40mA to 27mA so some was going that way.
              I changed the SIO which must have been faulty as the motherboard does now power up which it did not before. I doubt it is discharging into the SIO but I will lift that one leg just to eliminate the possibility.
              Rich
              • dicky96
                Sun Seeker
                • Mar 2017
                • 1825
                • Spain
                Ahaa - as there is a diode like you say and I read a foreward biased diode junction from CMOS battery +ve to ground then it would make perfect sense from my little circuit diagram that I have a short circuit from RTC power rail to ground even with the south bridge removed.
                • piernov
                  • Jan 2016
                  • 4437
                  • France
                  Ah if you removed southbridge you should be able to check RTC power rail resistance/diode mode to ground easily by identifying corresponding ICH pad from ICH datasheet ballout.
                  • dicky96
                    Sun Seeker
                    • Mar 2017
                    • 1825
                    • Spain
                    I found where the 27mA was going
                    Basically it was my own fault, I found a small solder bridge on the SIO on the BAT+ pin to the adjacent one which would have been from when I replaced the SIO. I also found another solder bridge between two other pins so this is something I need to check more thoroughly in future
                    As the current from the CMOS battery went down from 40mA to 27mA when i removed the south bridge, and I have already ordered a replacement, I decided to put this on one side again until the parts arrive. I have some more SIO here (I ordered a pack of 5 as they were so cheap) so if i need to change that again it isn't a problem
                    Now the current from the battery is zero so the SIO is not drawing any.
                    I found the circuit diagram and that helped me. Here it is for anyone else who wants it.
                    • TinkerTron
                      Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
                      by TinkerTron
                      Hey everyone,
                      I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
                      Instead, here's what's been bugging me so far:
                      The schematic...
                      03-06-2025, 02:03 PM
                    • atunguyd
                      Acer x163w Monitor PSU schematic
                      by atunguyd
                      Ii wonder if anyone can help me. I have a Acer x163w monitor which is not powering up. The PSU main capacitor's one leg had completly come off - I replaced it but the PSU is still not outputting DC. I found the monitor in questions service manual here on manuals lib but the schematic in there is a completely different - the schematic shows no mosfet to drive the transformer while the one I have does use a mosfet - also the schematic shows only one optocoupler but mine has two.
                      The PSU board is labelled FM-20A02-AAA made by APD as per the image below. I am trying to find a schematic for this...
                      03-05-2025, 02:08 PM
                    • Thetechdude
                      MSI Ventus RTX 4080 16G Broadview schematic needed
                      by Thetechdude
                      Hi guys, I'm working on a MSI Ventus RTX 4080 16G. The GPU has 12v, 5v, however what I assume is the 1.8v rail has 1.1v and what I assume to be PEX is 0v. As you may have guessed already there is no Vmem and no Vcore.
                      I have looked around in related forum posts for a schematic so Much appreciated if anyone can share a Broadview schematic.
                      Thanks.
                      07-15-2025, 11:15 AM
                    • ianpoultonknights
                      Zenbook Flip 15 UX562AI schematic
                      by ianpoultonknights
                      Had one of these come in for repair with a blown battery and a WiFi issue, battery has been replaced with genuine battery (twice) and won't take a charge works fine on AC, WiFi issue gone away. Looking for a schematic so I can trace the charger circuit UM562F is only one I can find, this is the 562AI model.Had a unit come in for repair — 562AI model — with a blown battery and WiFi issue. WiFi fault has cleared, but battery won’t charge despite replacing it twice with genuine parts. Device operates fine on AC power. Suspect charger circuit fault. Only schematic I’ve found so far is for...
                      06-26-2025, 02:41 PM
                    • Adv10119
                      Need help please! schematic for LA-9982P rev 3.0 (A02)
                      by Adv10119
                      Please help, i need schematic diagram for Dell inspiron 3537 board LA-9982P rev 3.0 (A02). Specific for A02.
                      I have a one beep with no display problem. Did reprogrammed the bios but no luck. i tried to troubleshoot using rev 3.0 (A08) version schematic and boardview but there's components/rails in the schematic that is none in my actual board, this is why I'm having problem checking every power rail needed if ok. attached is the photo of my actual board.
                      I'm not sure if A02 and A08 is really different schematic version from each other, but I have to try....
                      01-31-2024, 01:18 AM
