Got this one in today, when you first plug the power cord into the outlet, you hear the relay clicks on but then clicks off.
Check 3.3VSTBY, it only shows about 0.25VDC. Removed the cable to the main board, power backup and then 3.3VDC is OK using dummy load.
Check the resistance 3.3VSTBY pin and Ground on the main board and it shows 3 Ohms. Start disconnecting the connectors attached to the main board, when the connector to the IR receiver/LED indicator board the 3 Ohms reading goes > 500 Ohms resistance.
Remove the IR board and inspect the MLCC and find that the C9101 10uF 16V MLCC shows 3 Ohms, so I replace it with lytics cap instead sine I have lots of room to install regular lytics cap.
TV now turns on and works just fine.
