I Need Advice on the purchase of a Multimeter
  • nephilim33
    • Jun 2012
    • 5
    Hi i am new to the forum and new to electronics, i am attempting to fix my first monitor and i want to purchase a multimeter that will do the job.
    Could anyone give me some suggestions on a multimeter that i can use for testing components. I would like to know what functions i am looking for in a multimeter for doing general work on boards. I would like to purchase a meter of ebay (convenient) that is in the low to mid range.
    So if anyone could let me know what type of meters there are to buy and what there pros and cons are it would be appreciated.
    A cheap meter would be ideal atm ( under 50$ ) but if its not going to be good for the jobs ahead ill spend more.
  • Spitz
    • Oct 2010
    • 95
    Re: I Need Advice on the purchase of a Multimeter
    I would suggest a Mastech Ms8264 or the identical Sinometer Ms8264. Some people say the sinometer is a less quality item. I cannot comment on that since I have not worked with one. This meter is a decent low cost meter that will do everything you need short of testing capacitors. That requires a seperate esr meter.
    • nephilim33
      • Jun 2012
      • 5
      Indeed as i have learned reading the threads, Could i also get a recommendation on a good cheap esr meter.
      • RON_CET
        • Jun 2012
        • 217
        I'm partial to Fluke DVM, but nothing wrong with a Tenma DVM from mcm electronics for someone just getting started
        Ron Driver,BSEE,CET,ISCET,NESDA
        • Spitz
          • Oct 2010
          • 95
          Not the cheapest but my favorite is the ESR-micro v4.0. It displays both parameters at the same time. Also on the multimeter the ms8264 has a manual function dial, if you want an auto-ranging meter then the model is Mastech MS8268. Auto-range meters are a little slower at getting a stable reading.
          • JimmysTGP
            • May 2012
            • 45
            • US
            Same here on Fluke based on experience with everything else I've purchased and destroyed. I can't kill this Fluke had it 12 years. However you don't want to pay $300 for something that your never going to use it everyday, theirs a Fluke 119 ranging around $100 that might do everything you want.
            • retiredcaps
              • Apr 2010
              • 9271
              1) Your fellow countryman, Dave Jones over at eevblog.com, has a $50 multimeter shootout
              http://www.eevblog.com/2010/06/04/ee...eter-shootout/
              2) A buyer's guide is also at
              http://www.eevblog.com/2010/04/14/ee...-buying-guide/
              3) Martin Lorton buyer's guide
              http://www.youtube.com/watch?v=jC_Qh...ure=plpp_video
              4) If you are patient, you can get some good deals on used multimeters off ebay (like I have).
              --- begin sig file ---
              --- end sig file ---
              • retiredcaps
                • Apr 2010
                • 9271
                I'll contest the above as a not being true as a general statement.
                I have now used about 15 different multimeters both autoranging and manual from different manufacturers.
                Some autoranging multimeters inlcuding my Fluke 27 are slow to display a reading since it only updates the screen 2 times/sec. Others like my Fluke 83III are lightning fast at displaying a reading (4 times/sec). I also have some manual ranging multimeters that are very slow (worse than 2 times/sec).
                For troubleshooting lcds, I think an autorange multimeter is more efficient than a manual. While troubleshooting, I may have to measure the large filter cap (165V DC), the 5V standby, secondary voltages like 24V DC and some voltage regulators at 1.8V DC. For an autorange multimeter, I just leave it on the DC V setting. For a manual range multimeter, I have to switch the dial 4 times (200V, 20V, and back to 200V to 2000mV) in the above scenario.
                • retiredcaps
                  • Apr 2010
                  • 9271
                  I think you made a typo, there is no Fluke 119, but you can get a brand new Fluke 117 off USA ebay like these 2 auctions (now ended)
                  http://www.ebay.com/itm/280899544934
                  http://www.ebay.com/itm/140770155470
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    There is also a Fluke 179, which if you are patient, can be purchased in the $100 range off ebay.
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      From
                      https://www.badcaps.net/forum/showpo...67&postcount=4
                      Originally posted by walking
                      Unless you're going to later "fix" heart monitors or passenger aircraft systems don't spend more than $20.
                      I managed to get a Fluke 27 for $20. Although it is probably more than 20 years old, it is as accurate as my other Fluke multimeters and MORE accurate than the non Flukes.
                      PS. I'm not a Fluke fan boy, but it is the easiest multimeter to purchase used as there are quite of few them versus every other brand. I have managed to get 6 used Flukes for under $50 each (sometimes well under).
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        From
                        https://www.badcaps.net/forum/showpo...27&postcount=5
                        Originally posted by scampo77
                        you need to look for 2 things fixing monitors. for the meter you need to find is a true RMS meter. these are far more accurate and far more stable.
                        We, the regulars, rarely, ever ask people to do any sort of AC measurement. So for troubleshooting lcd/TV purposes, a true RMS multimeter is not required.
                        We usually ask for DC voltage and resistance measurements 99% of the time. We also rarely ask for current measurements.
                        when measuring a voltage regulator that is +- 10% and it is 1.8v the difference between 1.86v and 1.78v can really help you when diagnosing these things.
                        I hope you mean 1.0% (one) percent. And voltage regulators found in lcds/TVs are usually DC voltage regulators so no true RMS is required.
                        • Davi.p
                          Not a repair, only a purchase advice ask for
                          by Davi.p
                          Hi, briefly for a purchase advice i would like to know from experts if recent LG still suffers processor soldering problem, like almost every LG led tv i know. Thanks.
                          04-13-2022, 08:44 AM
                          Modification of a Fluke multi meter that uses three AA batteries to use a 14500 lithium ion battery
                          by sam_sam_sam
                          I have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
                          I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery...
                          12-31-2023, 06:04 AM
                        • TOMÁŠ
                          MacBook Air A1932
                          by TOMÁŠ
                          Hi, I've never worked with a MacBook before, so I need some advice.
                          I have a MacBook Air A1932 (820-01521). When I plugged in the charger with an amp meter, it showed 19.7V and 1.9A, which indicates that it's charging, but when I press the power button, it doesn't turn on. So, I disassembled it, disconnected the battery, and plugged in the charger again. It showed 19.6V and 0.04A, and pressing the power button had no effect—no current draw at all. Then, I removed the motherboard, connected the charger again, and got the same results. I took a multimeter and checked all the coils, and everything...
                          05-20-2025, 11:19 AM
                        • Tarot Superstars
                          Short Circuit tester
                          by Tarot Superstars
                          Hello.
                          I have seen a short circuit tester made with 3 * 9V batteries, a voltage limiter component and a resistor connected to the probes of a multimeter.
                          The theory is that the meter becomes sensitive enough to read very low resistances and the lowest resistance to ground on a circuit is likely to be a short circuit in that area.
                          Link
                          The Amazing $1 Short Finder Upgraded! Convert ... - YouTube
                          https://www.youtube.com/watch?v=0eixDdCpiO4
                          My multimeter isn't normally sensitive to very small resistance, but when I put a 1 mega ohm resistor...
                          09-25-2023, 09:11 AM
                        • flibidy
                          Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
                          by flibidy
                          I have here a Magnum IA.100 which belongs to my parents.
                          The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
                          Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
                          What Ive done........
                          01-01-2025, 01:26 PM
