Plasma Cutter Giant Tools LGK-60 not working
This topic has been answered.
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8351
    I've got a Giant Tools LGK-60 Plasma Cutter here to repair.
    Complaint: It does turn on, the display is on, consumables had been replaced, when the trigger is pressed the air valve opens and that is about all she does.
    So I've opened that sucker up, checked the inverter o.k., checked the arc board o.k., came to look at the 400V 470uF main filter caps on the power supply and
    You think there is sumtin wong here? All 6 of them look like that!
  • Answer selected by CapLeaker at 04-16-2025, 07:22 PM.
    CapLeaker
    Leaking Member
    • Dec 2014
    • 8351
    Re: Plasma Cutter Giant Tools LGK-60 not working
    Well guys and gals... The plasma cutter is FIXED! The last problem was that the control board didn't get the signal to turn on.
    Besides the bad main filter capacitors, the trouble was actually on the arc board. The turn on signal was there for the air valve, but not for the controller board to turn on the inverter. I chased things around on the arc board and found 2 bad 22k resistors R6 and R15. R6 was way out and R15 was out of spec. Changed them out (look at the brown resistors) put it back together and I got 465V AC from the inverter, but no arc. Adjusted the spark gap FDQ to roughly 1.25 to 1.50mm and low and behold I've got the arc going in between them plates. Finally that case is closed and that stupid thing isn't smarter me.
    This fix is for those that have the air valve go, but no AC voltage coming out of the inverter board when keyed. So there will be absolutely no spark from the wand, acts like dead.
    On the arc board the trigger goes to CN5 (blue and green wire). The turn on signal for the controller board is on CN4 (the one on the right to CN5) and has a red, blue, green wire.
    Between that blue and green wire should be 5V DC going to the controller board when triggered.
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      That appears as heat related damage. Pull them out and check values. I'd opt to change them out for a start.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8351
        Oh yeah... those got hot alright somehow and needed to be replaced.
          • Jul 2011
          • 6070
          Does unit have a IGBT module if it does after you recap it that would be the next thing to check to see if it is getting the command to turn ON
          Make sure you replace the caps near the IGBT module if it has one
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8351
            The inverter has a bunch of MOSFET's 2SK4108 in it and those are good. The rectifiers diodes are good too. I didn't see any other caps on the inverter board, when I took it apart, but I am going to have another look. Have to wait on what the owner wants to do anyway...
              • Jul 2011
              • 6070
              What micro controller does it have
              • CapLeaker
                Leaking Member
                • Dec 2014
                • 8351
                I don't know... didn't take it that far apart (yet).
                My theory right now, is that it is still a main filter capacitor problem. I did take a few of them caps out and checked them on my ESR meter. They show something like 20% down, with the ESR being at 0.22 Ohm. That doesn't mean they aren't breaking down at a higher testing voltage. I have a friend lined up with a proper tester that actually can charge the cap up to 400V and measures the leakage. We will see what happens.
                • CapLeaker
                  Leaking Member
                  • Dec 2014
                  • 8351
                  So I went and checked these caps with a proper high voltage tester. All of them have high ESR over 2.5 Ohms at rated voltage and leaking. That is exactly what I figured. I also came to find out that this Plasma Cutter was hooked up wrong at one point. That issue got fixed and the unit ran for a bit, then quit, then I've got it to repair.
                    • Jul 2011
                    • 6070
                    So That issue got fixed and the unit ran for a bit, then quit, then I've got it to repair.
                    Where I work at this happen all the time or at least it seem to be the case
                    • CapLeaker
                      Leaking Member
                      • Dec 2014
                      • 8351
                      yeah, for some reason most of the time it always ran after an event for a lil while... I don’t think it was running any after that whatever happened to it..
                      • CapLeaker
                        Leaking Member
                        • Dec 2014
                        • 8351
                        So...got the new replacement caps, put them in and the plasma cutter still does the exact same thing. No workie. Grr. Guess I am pulling the arc board next, unless someone has a better idea.
                          • Jul 2011
                          • 6070
                          Can you please post the photo of all of the boards in this unit
                          • CapLeaker
                            Leaking Member
                            • Dec 2014
                            • 8351
                            Well, I don't have all the boards out, but I did take out the PSU and the arc board. I've rechecked the PSU and that is 100%, even took the blue relay and the mosfet out and tested it o.k. Also checked the Thermistor (little black box) o.k.
                            Now to the arc board: All diodes, transistors, caps and resistors are good. Can't find anything wrong. Those green PTC's measure 450 Ohm and the other 530 Ohm. Kinda weird value or something?
                            • petehall347
                              • Jan 2015
                              • 4448
                              • United Kingdom
                              does it have an arc gap like some tig welders ?
                                • Jul 2011
                                • 6070
                                I would also add this you need to find out if it is getting the command to ( fire )
                                start if not why not and do the 4 big caps getting any power
                                • CapLeaker
                                  Leaking Member
                                  • Dec 2014
                                  • 8351
                                  Yes (second pic, where the 3 blue HV caps are, marked F00), I cleaned those and played around with the gap to no avail.
                                  I know the trigger works, a relay clicks and air comes out. However, I am not sure if the arc board is getting the command to fire. I've got no schematics or anything to go by. The PSU is 100% and power is available.
                                  • CapLeaker
                                    Leaking Member
                                    • Dec 2014
                                    • 8351
                                    Here are more pics. All fets and diodes are good. All resistors at each of the fets are good. All big wire wound resistors are good... there is nothing I can see, but it still isn't working. The relay on the PSU is good, the relay on the arc board is good too. The temp sensors are good and slowly I am out of ideas. The control board is on the top, next to the inverter.
                                    • petehall347
                                      • Jan 2015
                                      • 4448
                                      • United Kingdom
                                      continuity to torch for sanity
                                      • petehall347
                                        • Jan 2015
                                        • 4448
                                        • United Kingdom
                                        no idea how they work but i see high voltage caps in there that may be leaking .. just a thought like .
                                        • CapLeaker
                                          Leaking Member
                                          • Dec 2014
                                          • 8351
                                          been there and checked out good.
                                          Well, I gave it more thought: The arc board (or HF board) only can arc, if it has power and that comes from the inverter board. If the inverter doesn't switch on, I am thinking that the arc board won't switch on either. That leaves the control board (or driver board for these fets) and the driver transformer board. After all, if the fets aren't driven from a PWM, then there is no power, right? Maybe the PWM is fubar? Food for thought.
                                          • capwizard
                                            Plasma TV to A Plasma Cutter.
                                            by capwizard
                                            I try to reuse Plasma TV IGBT parts for A Plasma Cutter and cut Plasma TV's metal cover!... I just need to cut through TV sheet metal. Budget is $10.00.............. Any help?
                                            How To Make a MINI Plasma Cutter! (easy)
                                            https://www.youtube.com/watch?v=yCUGh9F4lis
                                            How to Make Your own Plasma Cutter.
                                            http://www.instructables.com/id/How-...Plasma-Cutter/
                                            Opperation of Home Made Plasma Cutter
                                            https://www.youtube.com/watch?v=SuSqlZe9HYU
                                            Chinese 50 amp plasma cutter WOW!!!!
                                            https://www.youtube.com/watch?v=...
                                            02-14-2017, 09:51 AM
                                          • Hexram
                                            Tools - Order of purchase
                                            by Hexram
                                            Hey guys,
                                            I am new to the electronics repair game & have stumbled into some tools to get my workshop (garage) started.
                                            I managed to get my hands on a low budget multi-meter, soldering iron, de-soldering gun, oscilloscope and a variable voltage/amperage DC power supply.
                                            With this being a new hobby i am thinking of investing in some tools to make it a little easier.
                                            When i get paid next i was thinking of buying a Peak Atlas ESR 70 gold.
                                            I am after suggestions on what order to buy things because i don't have the money...
                                            04-24-2023, 04:03 AM
                                          • ArMaaN376
                                            Samsung PS51E550 Plasma TV
                                            by ArMaaN376
                                            I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
                                            Opened TV cover & observed foll
                                            a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
                                            b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
                                            c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
                                            How to confirm Y -Buffer board...
                                            06-19-2024, 04:05 AM
                                          • jm1234
                                            Panasonic plasma TX-P42ST50 - 6 blinks
                                            by jm1234
                                            anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                                            It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                                            I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                                            I checked that board for any obvious faults...
                                            05-22-2024, 06:59 AM
                                          • KYBOSH
                                            Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
                                            by KYBOSH
                                            Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
                                            No picture but you hear the TV static (white noise) playing loud and clear.
                                            The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
                                            But it seems they didn't get too far and just left it.
                                            When I first took a look I was amazed at how pristine the inside looked.
                                            Its as if the TV had been in a time capsule.
                                            Caps looked like they were just pulled off the self.
                                            Copper coils had no sign of corrosion on...
                                            02-01-2023, 11:10 PM
