Tc-p55ut50 8 blinks
  • ricosavy
    • Jul 2012
    • 457
    • united states
    Re: Tc-p55ut50 8 blinks
    Here pic for tc-p55ut50
    • ricosavy
      • Jul 2012
      • 457
      • united states
      I see board tnpa 5592 i think it has the same ic chip i am looking for.runs about 17 dollars for board just hard to tell if it is it.
      • ricosavy
        • Jul 2012
        • 457
        • united states
        Well finally got the ic C0ZBZ0001936 i replaced it and bad mosfet that shorted again when i did not replace the ic the first time.Turn the tv on no more 8 blink code and i have picture.
        • tw2005
          • Oct 2011
          • 6458
          good info, so in essence the usual bits failed but needed driver IC. So if looking for a kit pick one that has that driver chip would you say the best option.
          • ricosavy
            • Jul 2012
            • 457
            • united states
            Yes that is what i would do
            • line6
              • Oct 2016
              • 5
              • us
              #26
              Hi, i did the same thing order the kit from shopjimmy the tv worked for about 15 seconds then the picture went away and started giving me the 8 blink code again. so that brought me here. so it looks like i need to replace ic153 along with the kit parts. But i cant not find a place to order the ic153 any one know where i can get this? thanks
              • tw2005
                • Oct 2011
                • 6458
                try a google
                http://www.searspartsdirect.com/part.../0057/528.html
                C0ZBZ0001936
                https://bestbuy.partsearch.com/Part/...01936/New.aspx
                made by ROHM BD8694
                • line6
                  • Oct 2016
                  • 5
                  • us
                  #28
                  Originally posted by tw2005
                  Ah thanks looks like sears has it in stock will get that. on a side note isnt BD8694 ic152 and its a bigger size found on the 50 inch panny. can you use that instead. the board has a spot for either. i wonder?
                  • tw2005
                    • Oct 2011
                    • 6458
                    Yeah ok better disregard I can't check at the moment. I thought you were referring 55 same as this thread. So yours is the smaller driver ic and ic152 is not populated.
                    I hope you have not rushed and ordered it yet I say that I have given you the wrong info sorry
                    • tw2005
                      • Oct 2011
                      • 6458
                      Could be BD8693 have a look at what is on your ic. D86 93 ?
                      • line6
                        • Oct 2016
                        • 5
                        • us
                        #31
                        yes i have the 55inch. mine is the smaller driver (ic153). And ic152 is not populated. on my ic it is marked 4840 m15 JRC. havent order yet.
                        • tw2005
                          • Oct 2011
                          • 6458
                          yeah ok well my head is muddled now. In the manual for a 55UT50 IC153 is listed as C0ZBZ0001936.
                          If the Ic does not have D8694 on it then I must be wrong as JRC stands for Japan Radio Company and on that basis searching I find NJW4840
                          High Speed Switching Gate Driver.
                          So C0ZBZ0001936 must be NJW4840
                          Edit> looking at images of a BD8694 I think you're right. It's the larger IC. IC152 on a 50" is C0ZBZ0001920
                          It's all a bit tricky with different versions but I found some images for C0ZBZ0001920
                          https://www.chsinteractive.co.uk/ele...-txp42gt50.htm
                          • line6
                            • Oct 2016
                            • 5
                            • us
                            #33
                            Ok so im going to order C0ZBZ0001936 from sears. and give it a try
                            • ricosavy
                              • Jul 2012
                              • 457
                              • united states
                              #34
                              Sorry i did not answer earlier i got it from sears.Just saw your email, tw2005 was the one who gave me the link.After replacing ic it worked great still using tv as of today.Should have posted the results and link.The ic on 55 was smaller size ic Than one on 50.Weird thing is shopjimmy includes ic on 50 but not on 55 inch.You will also have to replace mosfet again.
                              • line6
                                • Oct 2016
                                • 5
                                • us
                                #35
                                sears and best buy have returned my money. they dont have the part. kinda stuck now. cant find it anywhere else.
                                • ricosavy
                                  • Jul 2012
                                  • 457
                                  • united states
                                  #36
                                  They said they have it
                                  https://encompass.com/item/9529293/P.../C0ZBZ0001936/
                                  • Biruslapio
                                    Panasonic P58V11B 8 and 12 blinks error "fix"
                                    by Biruslapio
                                    Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
                                    Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
                                    04-13-2021, 07:13 AM
                                  • Nairolf
                                    Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
                                    by Nairolf
                                    I have a Samsung DM32D display.
                                    When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
                                    Here’s what I have tried so far:
                                    1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
                                    2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
                                    3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
                                    From these tests, I suspect the problem might be on the mainboard. Could anyone...
                                    08-24-2025, 03:47 AM
                                  • Andre Gilbert
                                    by Andre Gilbert
                                    Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                                    Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                                    11-20-2024, 08:52 PM
                                  • Taurus12
                                    Optiplex 3050 micro 2 blinks followed by 3 blinks issue
                                    by Taurus12
                                    Does anyone have an idea of what might be the issue with my 3050 micro? I have tried replacing new cmos battery but still the same
                                    I am not sure if its the powersupply that I'm using is the issue since its the original powersupply. its a laptop powersupply with the same specifications with the 3050 micro so i guess it should be fine.
                                    i also tried replacing the bios but with no avail, everytime i try another bios it gives a different blinking lights
                                    Any recommendation on what I have to do next? Thanks in advance
                                    06-10-2025, 05:05 PM
                                  • jchon
                                    Sony A1e 5-blinks help
                                    by jchon
                                    Hi I'm new to trying to repair TVs, but I saw a broken OLED offered for a reasonable price and thought I'd try my hand at it.
                                    I found the service manual, which was critical to know where to probe.
                                    https://www.manualslib.com/manual/20...1e-Series.html
                                    With it I was able to determine that my DKA board was bad, when P_ON#1/2 gets enabled REG_12 on the DKA board collapses. I'm assuming one of the downstream regulators has a short, but I couldn't work out which rail/component and replaced the DKA board entirely.
                                    Unfortunately the 5-blinks...
                                    06-28-2023, 11:52 AM
