LG 60lf6090 Horizontal Faint lines only in darker shades of grey
  • sstevenson72
    • Apr 2017
    • 5
    I have read many posts on the Horizontal lines, but I feel those are different then the issue I am seeing as they have distinct horizontal lines in the picture. Whereas mine the picture is fine until you start getting into the darker not so bright shaded areas containing grays. I am curious if this might be a TCON issue or Mainboard. Maybe cables as I have seen that mentioned in a few posts. I will attach the images of what I am talking about. Notice the standard parts of the picture seem to be perfectly fine but the gray's
    I am hoping this has been run into before and I am just missing the previous post but I could not find it based on this specific model either by google or forum search.
    Forgot to mention I have tried from multiple sources to the TV to see if the lines would go away. This actually happens without any external source. If you look at the LG screen indicating no source connected the problem is prevalent. Just as it is on the Short lived LG Boot screen.
  • terryowens
    • Dec 2019
    • 4
    Re: LG 60lf6090 Horizontal Faint lines only in darker shades of grey
    Can confirm my 60LF6090-UB is also exhibiting this EXACT annoying condition as of this week. Is this a panel failure symptom or is there any hope to save my 60 inch?
    • nomoresonys
      • 12323
      • U.S.
      Looks like bad gate driver, maybe try the "cut tape" method, sometimes you have to play with position of tape : https://www.youtube.com/watch?v=j7vl7-vZEL8
      • nomoresonys
        • 12323
        • U.S.
        Last lg it worked on: https://www.badcaps.net/forum/showth...490#post930490
        • terryowens
          • Dec 2019
          • 4
          Thanks for the reply. The symptom for the LG in that link is different than symptom I'm currently experiencing on my 60 inch. My symptoms look just like the pictures in the OP's original post and there are very few instances of this exact symptom documented, much less reported as fixable.
          Thanks all for your suggestions and experience.
          • terryowens
            • Dec 2019
            • 4
            Some updated pics linked to imghost
            • terryowens
              • Dec 2019
              • 4
              I uploaded the same pics to the forum for posterity and longevity in case the image host disappears one day.
              • nomoresonys
                • 12323
                • U.S.
                Your tv is a 5 year old 1080 p tv, BELIEVE me, it's nothing we haven't seen a thousand times over.
                • howardc64
                  by howardc64
                  07-24-2025, 05:17 PM
                • Ihandyrepair
                  Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
                  by Ihandyrepair
                  Hi guys
                  I just started fixing 4k TV few months ago. so I am still learning a lot
                  I got this tv from friend complaint is ghosting or horizontal lines on image.
                  never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
                  then it started to show the ghosting white image.
                  I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
                  it has 3 thin small boards at the bottom of the...
                  12-05-2022, 04:18 PM
                • ggil44
                  Sony XBR-65X750D Horizontal lines bottom of screen
                  by ggil44
                  Hi, I have a Sony XBR-65X750D that has horizontal lines at the bottom 6 inches of the screen. These lines appear to be every other line because the picture is still quite visible behind those lines. The lines appear all the time with a few other lines above and below the 6 inch level blinking on and off at about 2 second intervals. I'm not sure if this is a panel issue or power supply/main board problem. I did replace the T-Con board without any change in the problem. Any suggestions you might have would be greatly appreciated. Thanks,
                  05-30-2023, 07:51 PM
                • rstrube
                  ViewSonic Pf815 (branded as P225f) Horizontal Deflection Issues - Running out of Ideas
                  by rstrube
                  Note: apologies I initially posted this request for help in the wrong forum! I am reposting it here and will take down the original posting.
                  Hi Everyone,
                  I've been working on repairing this beautiful CRT monitor off and on for the past several months and I'm really at a loss for what might be causing the problem.
                  Unlike other common Horizontal Deflection issues which result in a steady vertical line, when I turn the monitor on, there is a pulsing (somewhat segmented) vertical line. I've attached a photo that shows the issue (difficult to capture without video)....
                  11-23-2025, 01:37 PM
                • rstrube
                  by rstrube
                  Hi Everyone,
                  Unlike other common Horizontal Deflection issues which result in a steady vertical line, when I turn the monitor on, there is a pulsing (somewhat segmented) vertical line. I've attached a photo that shows the issue (difficult to capture without video). The monitor itself is branded as a P225f, but it turns out that it's actually a Pf815 that has an Add-On smallish PCB that expands it to support...
                  11-23-2025, 12:19 PM
